I need to slow down a hydraulic cylinder
   / I need to slow down a hydraulic cylinder #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
and I'm not sure how to do it.
The cylinder is what rolls my new ford two bottom plow over.
(hah, new to me, built in 1956 or so)
I cleaned out the cylinder and replaced the hoses and hooked it up and pulled the lever.
WHAM!!!!
It was violent!!!!! Turned over in about 1/2 a second.:eek: Scared the crap out of me. :eek:
Broke a piece of linkage.:mad:
I've heard of putting an orifice somewhere is the lines but I need to know how and where. Are fittings available that are already restricted. Is it just gonna make my tractor bypass. Does that hurt anything?
I would like this thing to take about 3 to 5 seconds to roll over and I can do that by feathering the controls but that's a pain in the patoot.
Suggestions???
Has anyone "actually" done this???
Ok I shoulda searched first.
Lots of info on "orifice";)
y'all can still reply if you want to. :)
   / I need to slow down a hydraulic cylinder #3
Sounds like you found the answer.. You can get many orifice parts at TSC.. I saw some there on there shelf.. not sure if they were pipe, ORB, or JIC.. but you can check. I'll bet your stuff is pipe for that old cyl.. right?
soundguy
   / I need to slow down a hydraulic cylinder #4
What size hoses did you use? Downsize them to car brake hose diameter. You can buy an oriface restrictor to cut down the flow or add a bypass.
I replaced the hoses with the same size that were on it when I got it, 3/8 inch I think.
They cost me $53 so I'm gonna keep them and just restrict the flow.
I've been looking at restricted connector this morning.
Should be easy to get what I want.
Thanks
Well whaddaya know.
Problem solved. Went down to the Deere store at lunch and bought a restrictor.
1/2 inch male and female pipe threads. Itty bitty hole thru the middle. $4.45
easy enough.
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
