Bob_Skurka
Super Member
- Joined
- Jul 1, 2003
- Messages
- 7,615
I really don't like to get into a lot of specific tractor recommendations but since you mentioned the 3 brands you are considering, I'll venture 2 recommendations to you. For a fairly basic machine at a lower price, the Kubota B7800 is a lightweight tractor with 30hp that has an excellent reputation for mowing with a 72" mid mount finish mower. If you want deluxe features, the upgaded lightweight tractor would be the new B3030. Both tractors are near mechanical twins and have similar weight and identical engines. Both are very light machines at just under 2000# are roughy 500# to 1000# lighter on the turf than most other 30hp tractors.
While the B3030 is a new tractor model, I am not afraid to recommend it simply because it is just an upgraded B2910 which is well proven and because it share well proven mechanicals with the B7800. The B3030 gets you a lot of deluxe features that are options or simply not available on the B7800 and you may or may not find things like the deluxe suspension seat worthwhile. So you can decide what trim level you would like. I'm not a big fan of the "90" series JD tractors (cramped operator station for my tastes), but at 32hp, the 4310 (which I think is being phased out?) is a amazingly well thought out tractor!
As for tire choices, I use a Kubota B2910 and a New Holland TC24 and both of them have R4 industrial tires on them. For the most part, if you stay off the turf when it is wet, and if you stay out of 4 wheel drive, the R4 tires will be good for mowing the lawn. They may occasionally "cut" the turf on the corners, but not typically when the tractor is in 2wd. Now if I was mowing a lot of stuff on a manacured lawn around very nicely kept flower beds, then I might opt for turf tires.
You mentioned that you're FEL work is going to be fairly light, and I feel compelled to say that of the 30hp tractors on the market, the "B" series Kubotas have lower capacities than some of the other brands. So while the light weight is a benefit for your primary task, it will lower your capacity for FEL work. Being that you are not planning any heavy duty long term use, I don't see that as a problem, but feel it is fair to point it out. Both will work a 5' box blade for dressing your driveway. But SonnieP just ordered a DuraGrader and I am curious to see how that works for driveway maintanence. Another common brand is Land Plane. Both seem to be similar in that they are designed to take the ruts out of a gravel drive.
With tractors you need to really take a look at the tasks you want to do. Some tasks are best accomplished with a HEAVY weight machine, other tasks are best accomplished with LIGHT weight machine. Some are best accomplished with a HST transmission, others with a GEAR transmission. Some are weight and/or transmission neutral. Each tractor is suited to some tasks and not to others so look at the characteristics of the tractor (weight, physical size, turning radius, width) and see what is BEST suited to YOUR situation.
MY OPINIONS (but bear in mind any tractor can be made to do any job, I just feel these are the 'optimal' combinations):
Mowing = light weight, HST
FEL work = weight neutral as long as you get the capacity you need, HST
Box Blade = heavy weight, gear
PHD = weight neutral, transmission neutral
Rotary Cutting = leaning mid to heavy (depends on the cutter), HST
Tilling a garden = light weigth, HST or Gear IF it has a "creeper" range
Planting a garden = light weight, transmission neutral
Cultivating = light weight, HST
logging = heavy weight, gear
Snow Blower = weight neutral, HST
