I need help with oil Please!
   / I need help with oil Please! #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
I am looking for sae 140 to go into a gear box on an old baler. Do they still have it and where can I get it? Is their a substitue?:confused:
   / I need help with oil Please! #2
Does it have to be single viscosity; i.e., SAE 140, or can you use the multiple viscosity oils? I know AutoZone has the Coastal 85W140 and I'll bet most other auto parts stores do, too.
   / I need help with oil Please! #3
If you decide you need single viscosity, try a petroleum specialist. Every city has them. I used to have to get aviation oil from them and they stock various oils. They are probably more knowledgeable than the average AutoZone type employee about oils as well.
   / I need help with oil Please! #4
Yes straight 140 weight is available but usually only from people like me who sell oil. You will probably have to contact a local oil distributor to get a straight weight these day's. The best thing to do is go with a multi-viscosity oil. My suggestion would be to use a 85W/140 if you plan on using conventional oil. You will get all the benifit's of easier operation at cold temps while maintaining the film strength of a 140 weight at operating temp.
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2007 Ford F-750 Chipper Truck (A52377)
2007 Ford F-750...
