Buying Advice I need help replacing my JD 790
   / I need help replacing my JD 790 #31
High range on a HST is mostly for travel and have limited power.
It is a heavy tractor also with the backhoe.
So today I had time to take the backhoe off. Let me tell you that I had more time in mounting my 5' finish mower than me and my wife had putting the backhoe on. She backed the tractor over the sub frame I plugged it in and bumped it around and boom the pins were in done! I spent a little time mowing today and I think I have something wrong with my transmission. Going on the slight down hill the thing rips along in medium, I turn around and go back up hill and I have to keep giving it more fuel to keep the pto speed and back off the HST pedal. Like I said the hill is hardly a slope it's about 5' in 200 yards, we shot it with a laser when we tried to put in some drains for the standing water. In high range with the mower on back (transporting it not cutting) it still struggles to move unless you are heading down hill.
   / I need help replacing my JD 790 #33
Go to the dealership and test ride an other one and compare. By the description you are giving something isn't right. I have been mowing with mine a 7ft finish mower, set the Rpm just a tad past PTO speed and as I hit the high grass it falls right to PTO RPM and stays. I cut up down and sideways and only at the highest steepest part do I have to back off the pedal. If I stay on it full it will bog just below PTO RPM but it dosnt stall or bog nearly enough for me to have to slow down for any other reason than I feel the cut is better at 540 PTO so I don't let it drift past it low or high by very much at all.
I actually tested mine today and rode to the lowest part of the yard and with the backhoe on I came back up in High gear at about 2000 RPM with no trouble at all. I actually had to slow near the top as I didn't want to hit the bumps that hard with the backhoe on.
As far as backhoe removal and installation it takes me about 5 min total to remove and reinstall it by myself. I do have a level concrete garage floor to do it on and it seems as long as everything is level it should always go smooth. Yes it takes me longer to mount the finish mower than to remove and reattach the backhoe but with the extendable 3 point arms that isn't even hard to do compared to using the 3 point on my old JD. I also leave the lower arms on when using the backhoe, as long as you leave them in the raised position everything fits just fine.
Forgot to mention I use M to mow so as long as your not stabbing the pedal like it was a dragster from a dead stop something must be wrong.
I was surprised at how easy it was to mount and dismount the backhoe! I removed it on the lawn and didn't have everything level so when I pulled a head the frame dropped a few inches, so when we put it back on I had to bump it up. A few practice runs and I know I will get quicker. And Paulfun9 you are right about the extendable arms, it was much easier to mount the mower than with my 790. I backed up to the mower and didn't have to push or pull on the mower once, I was able to get all the adjustments from the 3 point hitch. Actually the hardest part was lining in the spline on the drive shaft and that was always the easiest step on the 790.
As far as the transmission I am going to call the dealer tomorrow (they were closed today) and talk with them. I also noticed that in medium I can't spin the tires, I pushed up the wood shavings and horse manure pile and in medium it just slowed to almost a stall. I would have thought that in 2wd on top of 6' of wood shavings and manure I would have broke traction before stopping the tractor. Also when I was mowing, it seemed like I was getting plenty of power at the pto just not to the wheels. Going one way through a tall patch and the tractor didn't slow one rpm it seemed, but turn around and go back through on the up hill and I would have to rev it up and back off the pedal, even if I moved over to the already mowed area.
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
New Wolverine 78in Skid Steer Land Leveler (A59000)
New Wolverine 78in...
2020 CATERPILLAR 289D3 SKID STEER (A52709)
2020 CATERPILLAR...
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
