Buying Advice I need help replacing my JD 790
   / I need help replacing my JD 790 #1
Apsterbobed
Maine
DK40SE HST
Hello, this is my first post! I am in the market to replace my JD 790 with something larger. I am looking at the JD 4120 and the 4320. I was wondering what your opinion on those models is and if it is worth the extra money to go with the larger one. Also my 790 has turf tires on it and we run 4 chains on it all year round, due to the fact that most of what we do is loader work and we need the extra traction and some of the area is is hilly and the trufs struggled up on damp days. The 790 is also used for mowing a few pastures, about 8 acres with a 60" finish mower that I am keeping for now and grading my gravel road and driveway (about 1/10 of a mile). The new tractor will also be used for light fire wood logging for my own use and eventually putting in food plots for deer. We will also be using the tractor for clearing some forest to put in more pasture space. The other question i have is the tires, my first thought is go with the R1 because of the extra traction but I also like the idea of the R4 for the more durability and longer life. I fear that I will ware down the R1 using them to grade the road and plow snow or puncture them while in the woods logging or clearing land. Either way I plan on having them loaded for counter weight.
Also my 790 is up for sale if anyone in the central Maine area is interested.
   / I need help replacing my JD 790 #2
Are you set on green?
You could get a DK series Kioti 40/45/50 HP with a backhoe or cab for less than the JD open station, they also have the free loader program going on, don't snooze though, the DK series are tier3 emissions no computer, or exhaust treatment, when they are gone thats it.
My DK has a throttle cable, mechanical injection and governor, and a muffler...I like it that way :) Less is more:thumbsup:
They are being replaced by the NX series...Tier4 for 2014
All 2014 tractors must meet tier 4 emissions, with all the computer controls exhaust treatment etc.
Linky...Kioti Tractors
Ls also makes a good tractor, priced similar to Kioti
FYI my Dad has a 970JD he bought new in 97 it's been a great tractor, my DK is a Cadillac in comparison, he really likes my tractor.
Good luck
   / I need help replacing my JD 790 #3
I've had R1's on my 750 since new and have run a rotary mower in some pretty nasty conditions and never punctured a tire. In fact, the only drawback I've found with the ag tires is that they DO tend to tear up sod in some conditions (usually involving tight turns or 4WD), but even that is a minor consideration as I don't mow the lawn with it anyway.
Out of curiosity, why do you want to replace the 790? Not familiar with the HP or features of the models mentioned, but I have a serious aversion to increased complexity unless there are clear advantages. Plus, being a bit of a codger, I'd avoid the extra expense and complexity of Tier 4 diesels.
I've often thought of upgrading to a 790 for the synchro trans and the power steering but never came across the right deal.
I need something with more lifting power and more weight for the work I need to do.
   / I need help replacing my JD 790 #5
That's a pretty healthy jump (and $$$) from a 790 to a 4x20 series machine. You might want to consider one of the 3x20 series...or even a 4005 (renumbered 990). Frankly, if you're OK with a gear transmission (and apparently, you are), the 4005 would be my choice. Cheaper then a 4x20 series machine and plenty of power.
Nothing wrong with looking at other brands either...I'm a green guy too, but I'd at least look at the Kiotis.
   / I need help replacing my JD 790 #6
I bought a 4120 last fall. I did own a 4310 a few years ago ( same as today's 3320) I looked at the 3520 vs the 4120. Was about a $4k difference in price which put me at the top of my budget for the 4120 but went that route anyhow. Debated and was concerned that maybe I should have gone with the 4320 for the extra HP. I have about 27 hrs on my 4120 now plowing snow, pulling trees, and disking with a 6.5" disk. I have yet to run out of HP. Ran a 60" tiller and it acted like it wasn't there. So if you are concerned about HP don't be. As far as tires, I went with the R4's. Good compromise I think. No issues in the snow but does slip a little pulling the disc in 2 wheel drive with unloaded tires.
Thanks for the kioti tractor suggestion I went and had a look at them and with the loader program that are $10000 less than jd
   / I need help replacing my JD 790 #8
What Kioti tractors did you look at?
10,000 less is a lot of cash!
My friend is a JD guy threw and threw but after helping me to lock in a decision on what to buy last month and then actually putting it to work here at my place he is looking very hard at trading in His JD and getting a Kioti..
   / I need help replacing my JD 790 #9
If you're not fussed about having a cab-option I can recommend the JD 4105. (touch the woodpile) I've not had a problem with mine and it's done everything that I've asked of it. No problems with my R4 tyres either.
Yes, I'm a Green Bloke. There are heaps of other colours out there that are also very reliable... that being said (and noting that you already have a tractor) it's the after-sales support/reputation of the Dealership that counts.
Welcome to TBN, by the way, where we'll be more than happy to advise & help you spend your money. It's what we do! :laughing:
   / I need help replacing my JD 790 #10
Yes! You could get a Cab unit, with heat, A/C, Stereo/CD player and still be 5 grand less than the open station Deere....Or a Cab and a Backhoe, for about 1500 more than the open station Deere:thumbsup:
Don't get me wrong the Deeres are nice tractors...but so are Kiotis...and you get a lot of tractor for the money with the Kioti, The DK series are a very good value IMO..2761 lbs of lift on the loader, heavy,...Tier 3...no computer hockus pokus, no check engine lights, error codes etc, I think as some time goes on, these later model Tier 3 tractors are going to be very sought after machines.
I think your on the right track with the 40 horse frame size, you get alot more capable tractor for not to much more money:)
Great Plains Grain Drill (A50515)
Great Plains Grain...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2013 Ford F-250 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
