I need help finding my fuse on my Kubota b7300 hsd tractor
   / I need help finding my fuse on my Kubota b7300 hsd tractor #1
OSA 321
Kubota b7300 hsd
I looked and looked and looked for a fuse box on this Kubota b7300 hsd I've looked everywhere under the seat side of the engine I fought every wire until the end and I never have seen a fuse box just wondering if there is one on this unit or is it just a fusible link thank you for any help
   / I need help finding my fuse on my Kubota b7300 hsd tractor #2
Hopefully this helps:
Thank you I'll check it out
   / I need help finding my fuse on my Kubota b7300 hsd tractor #4
Yeah, it is not a traditional fuse box, per se, but a small plastic 'rectangular box' attached to part of the wiring harness on the left side sort of the middle of the engine, .
The only box I have is rectangle is a black box and I opened it up and there is a circuit board in it with a relay is that what you're talking about but I have no other boxes on the left side of my motor
Is there any way you can be more specific about the box and maybe the wires coming out of the pigtail thank you
   / I need help finding my fuse on my Kubota b7300 hsd tractor #7
I am not sure how you engine looks, but here is what the left side of my 1999 B7300 looks like with the 'fuse box' zip tied to a cable cluster. The fuse label still remains on mine, and you can read each item (instrument cluster, work light, hazard). I am not sure what fuse controls the headlamps. Hope this helps.
After re-reading the label, the first slot reads "head light instrument cluster'
BTW: Do you have a copy of the B7300 owner manual? I found a 'searchable' PDF copy (very handy) that I would be willing to share. Just send me a PM with your email address.
The 'work light' I found was just a hot wire off one of the rear light pigtails. I connected to this, with a switch, and control a rear facing 'headlamp'
SAMSUNG STEAM VRT WASHER & SAMSUNG MOISTURE SENSOR (A60432)
SAMSUNG STEAM VRT...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
