I need an electric diagram for JD 6415
   / I need an electric diagram for JD 6415 #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
What l specifically need is a diagram for the backup alarm on a JD 6415 with Power Quad Trans and Reverser.
I bought a backup alarm kit said to be for a JD 6415 missing a few parts. l thought all l needed was a pressure switch and the adapter fitting to install in the trans. Turns out there are two kits, one for the AutoPowr/IVT Trans and one for all other Trans. I got the wrong one.
So now, l also need the wiring harness and a relay. I was just going to buy the harness from the Dealer, but it's over $400. So if l can get a diagram, l'll make my own.
From the instructions the harness is part number AL158140.
It looks like it connects to connector all ready on the tractor. (l think 12V & ground) then there are connectors for the backup alarm, a relay, an ON/OFF switch, the pressure switch and a connector that l think is just a feed thru of the power connector all ready on the tractor, it connects to.
Any help will be appreciated. :thumbsup:
   / I need an electric diagram for JD 6415 #2
This should have the info you're needing
Technical Manual CD-ROM TM4649CD
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
378786 (A51573)
378786 (A51573)
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
