I Need an Earth-Mover-Thingie-Doo-Dad
   / I Need an Earth-Mover-Thingie-Doo-Dad #1
have_blue
Eunice, Louisiana
L4400
I have a lot of deep topsoil to move from a large area, and my FEL or a box blade would take forever. I don't have access to a dump truck either. Since I need to move the dirt several hundred feet, I would like to move at least a couple of yards per trip to avoid wearing me and my tractor out.
Attached is what I need, only in full scale. Unfortunately, the model is closer to what I can afford. /forums/images/graemlins/smile.gif
Has anyone built a pull-behind earth mover (or scraper, or whatever one would call them)? It seems very simple to design and build, but I don't want to re-invent the wheel.
I can envision something that is pulled with the draw bar, and the 3 Pt hitch would manipulate the blade and the dumping action. I could plow the topsoil and wait until it dries real fluffy because I have way more time than money. A long wheelbase should help prevent gouging, and result in nice level land on both the new area and the donor area. I hope I could pull it pretty fast and skim 2-3" at a time, and dump it in layers. Does this sound possible?
After the dirt project is finished, the implement would still be great for landscaping and road work. Any examples or ideas of such an implement?
Thanks!
   / I Need an Earth-Mover-Thingie-Doo-Dad #2
Check out irrigation sites and attachments for leveling fields. The impliment you are looking for is on the market but perhaps for larger machines.
Egon
   / I Need an Earth-Mover-Thingie-Doo-Dad #4
</font><font color="blue" class="small">( Here's what you need:)</font>
New Goodies! I want one of each of their products! Thanks for this link. John
   / I Need an Earth-Mover-Thingie-Doo-Dad #5
Don't know of too many options for CUT. Used to farm Cheneyville/Lecomte area and used land planes for contour and leveling, but took a 100hp more than you've got. Might could find one you could cut down to size. I've seen scraper pans also but still you wouldn't have the horseys to haul 5yds. It's cheaper to rent the right stuff than tear up a $20K tractor.
   / I Need an Earth-Mover-Thingie-Doo-Dad #6
I stand corrected and enlightened.
</font><font color="blue" class="small">( Here's what you need: )</font>
Hey, nice. I don't quite understand why it needs so much HP for such a small payload. Even hauling just under a yard, it looks like you could move a lot of dirt with it because you never have to stop or slow down.
I was thinking more along the lines of a big, low trailer with a scraper blade. Something I could fabricate. Something <font color="blue"> cheap. </font>
   / I Need an Earth-Mover-Thingie-Doo-Dad #8
Ill retake a few pics of a small pan I made when i was 14 in metal shop I pulled it behind an 8 HP Farmall Cub offset tractor. It was barely bigger than a regular 3 point scoop but could be made bigger for a modern tractor. Try to do a Google for Soil Mover scrapers they make a 2 yard pan for 2 000 dollars for a 25 to 30 hp tractor. Its also marketed under Durabuilt.
One other thing is to find an old fresno or tumble bug scraper they just drug on the ground on a thick heel and when you got to your fill you pulled a rope and it tumbled over emtying its load.
   / I Need an Earth-Mover-Thingie-Doo-Dad #9
I remember when I was about fourteen years old,my buddy was moving some dirt with one of those old pans behind his dad's 8N.He had me hang onto something on the rear and not knowing what I was supposed to do exactly,I did as he told me.We got to the drop zone and he hit the release rope...sent me flying up to the 3pt.I can still hear him laughing 30 years later /forums/images/graemlins/mad.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif
</font><font color="blue" class="small">( for a 25 to 30 hp tractor. Its also marketed under Durabuilt. One other thing is to find an old fresno or tumble bug scraper they just drug on the ground on a thick heel and when you got to your fill you pulled a rope and it tumbled over emtying its load. )</font>
Thanks! I'll check it out.
I was really looking for something I could fabricate myself, and would rather keep it mechanical. The one seen at http://www.hoelscherinc.com/prod_dbscraper.htm is a dream come true, but I don't have 4K to spend plus another big hit for hydraulics. I need something with a long wheelbase and a mid mounted scraper blade that won't make whoop-de-doos. Even the 4K beauty does not look like it would be easy to keep things level and bump free.
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
Fuel Tank (A51573)
Fuel Tank (A51573)
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
