I need an AR-15
   / I need an AR-15 #201
AR5 and AR7 were USAF Air crew survival rifles. One shot 22 Hornet rounds and other used 22 LR.
U talking about the M6 survival? I got a Springfield M6 with 22 hornet top barrel, 410 bottom. Folds in half with spare rounds in the but stock.
   / I need an AR-15 #205
MIL-SPEC is simply a short version of MILITARY SPECIFICATION. It has nothing to do with the process of milling. My company manufactures MIL-SPEC hydraulic hose for which a milling machine is not necessary.
Sent from my iPhone 2.0 using TractorByNet
   / I need an AR-15 #207
I wouldn't trade either of my present AR15's for 20 copies of the M16's (my original was still labeled an AR15) that I carried around for 3+ years in USAF in late 1960's.
When I first joined the "Be All You Can Be" Army, my M16 said "AR15" on the side. God bless that A2. :)
   / I need an AR-15 #208
Exactly. There are mil spec computers and phones etc. I assume there are mil specs for K rations too. Nothing to do with milling of metal.
   / I need an AR-15 #209
Davy Crockett most likely used a military spec musket, to kill his food ..
   / I need an AR-15 #210
I don't know if you guys have ever actually worked with MIL-SPECS, but they aren't any more stringent then most commercial specs. In fact, many MIL-SPECS has been superseded by commercial specs.
As far as "Every part is milled to a specific spec", all machined parts are milled to a specification (called tolerances). MIL-SPECS aren't necessarily a tighter spec as tighter specs can lead to less reliability.
Colt manufactured to a mil-spec in some components since those components were shared with the firearms sold to the military.
I was in the military for about a decade...worked in more then one DoD supplier (mostly QA in machine shops). MIL-SPECS aren't some holy grail...they're just specs.
Now, when NASA was involved, different story..and after the USS Thresher incident (in 1962), zero defects in submarine building meant zero-defects....but all in all, MIL-SPECS weren't really that stringent.
But, use of the term "MIL-SPEC" in advertising sure sold some Colt AR-15 rifles!
Yes my company is a defense supplier and we work with specs routinely. They can be vague or very detailed and precise. All depends on the application. Heck... toilet paper is available per MIL-SPEC P43988.
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
