I "need" a welder..?
/ I "need" a welder..? #41
Re: I \"need\" a welder..?
Sully2 said:
Awe...GEEZE!!! Now ya got me to thinking again....
Don't do that, just go out an purchase a good 220V MIG unit.
I may..? Guess Im still not convinced that a rig like the Hobart Handler 140 ( 115 volt) wouldnt do me A-OK for MY NEEDS..? Says it can weld 1/4 thick stuff.( Course it dont say that it takes 2 hrs...LMAO)
If I go with 230...I have to pull about 90 feet of new wire to get to where Id want the new outlet....with 115 volt Im already there..
"Duty cycle" and such dont mean a lot to me...I really could care less how much "time off" Id have to give a setup. Im sure whatever time out Id have to give it is a lot less than the "wait time" to stand in line at a welding shop! IF...IF I could even get my tractor TO a welding shop..( No trailer..and no vehicle I could pull it and the tractor BOTH..even if I HAD a trailer for it...)
Duty cycle I understand...but to me ( a total newbie to welding) AMPS are AMPS...so if I see someone saying that they do most of their small stuff at a 120 amp setting..then to me ( and I may be 10000% WRONG..?) it dont matter if the rig is powered by 440..230..or 120???
/ I "need" a welder..? #43
Re: I "need" a welder..?
I'll just repeat that I am real happy with my 115 VAC / 140 amp Lincoln welder, which has virtually the same specs as the Hobart. It has done everything I've needed to do around the farmstead in the past year, or so.
Knute
/ I "need" a welder..? #44
Trust me when I say that you will be grossly disappointed in any 110V unit for anything beyond minimalistic use, it is worth whatever expense it takes to install the 50 amp 220V line, there really is no comparison in performance.
/ I "need" a welder..? #45
There's an old saying: "It's the poor craftsman who blames his tools."
It is amazing how happy some of us low achievers can be with the minimalistic craftsmanship we can produce on our minamilistic budgets.
Knute
/ I "need" a welder..? #46
One bit of advise I might offer would be to see if your local high school or vo-tech offers Adult Ed welding courses.
I did this, and the shop where where I took my course had small Mig (no gas), larger Mig (with gas), stick, oxy and even a plasma cutter that we got to try during the course. Nothing like some hands-on before before you buy -- and the folks who teach these courses can be real pros.
/ I "need" a welder..? #47
Knute
Be that as it may.. I do feel that 110v welders.. mig or stick.. are really just made for light duty welding. That's not to say that you can't patiently work your !BLEEP! off and glue some big stuff together.. but it takes lotsa work.
I have a 110v stick welder. it's great on sheet metal and 3/16. 1/4 takes a couple passes.. or perferably.. both sides available to weld. Anything higher is .. well.. torture. Right now.. i take anything over 1/4 to work to use our big mig or big stick welder ( that is.. untill I break down and finally buy a big stick.. ). I have welded a 3/4 rod one time.. had to make a tractor repair, and rod on a lift link broke. I guess it took me a couple hours burning 5/64 and 1/16 sticks to get that rod glued together. I v-cut each piece to at least half the depth of the material, then welded up and worked my way around, chiping, and grinding and welding.. then roll the rod a bit and start over. I know i got 100% penetration that way.. but it was darn tedius. The lift link is still solid today.. , after 2+ years of use.. but if I had had a 225a arc welder and some 1/8 or 5/32 rod.. or even a good 180 mig.. I'd have done the job in 5 minutes with the mig.. or 15 minutes with the arc.. and that included all the prep and cleanup.
Soundguy
I have a 110v stick welder. it's great on sheet metal and 3/16. 1/4 takes a couple passes.. or perferably.. both sides available to weld. Anything higher is .. well.. torture. Right now.. i take anything over 1/4 to work to use our big mig or big stick welder ( that is.. untill I break down and finally buy a big stick.. ). ..[/QUOTE}
And thats all the larger I'd ever be welding on. As I said in my opening...items such as weld on hooks that are presently on ny FEL...those sort of items...
[QUOTE}
Soundguy
Whereas I..me personally...wouldnt have attempted to weld it! I'd have taken it to a pro somewhere and paid HIM to weld it properly. I dont mind ( I dont think??) making more than one pass down a 3-4 inch long weld..even down BOTH SIDES of say a weld on bucket hook.
I have a little project coming up. A 50 caliber ammo box "tool box" for my B3030. I can buy the material...I can cut it and grind it nice and square...cant "stick it together"..? 1/8th in and 3/16ths stock.
But thats OK fellas and I appreciate the input from almost everyone... I had never intended to answer anymore posts to this thread after I got the gracious reply of " go look it up elsewhere".
Knute
/ I "need" a welder..? #50
>Whereas I..me personally...wouldnt have attempted to weld it! I'd have >taken it to a pro somewhere and paid HIM to weld it properly. I dont mind ( >I dont think??) making more than one pass down a 3-4 inch long weld..even >down BOTH SIDES of say a weld on bucket hook.
I didn't have the option to run to town.. I had a tractor broke down in my driveway with 500# of dirt in a rear scoop and a seperated lift link arm... That's why I welded it.. vs taking it to work to fix..
Soundguy
/ I "need" a welder..? #51
I wholeheartedly agree with CRD.
I mostly agree with SoundMan.
I'm no expert. But, I learned to stick weld, oxy weld, and braze over 50 years ago. I've done it out of necessity ever since, unless I've been able to convince some unsuspecting soul into helping me also whitewash the fence.
When I needed to again get my own equipment a year ago, I was amazed at the difference between stick welders and flux core welders of the same amperage. I'd never used flux core or MIG at that time. There is absolutely no comparison.
I did exactly what CRD suggested. I took a 6-session, 3 hour per night course, over 8 weeks at the local community college. What an eye opener. If nothing else, it sure improves your trivia knowlege.
I'd already bought my wimpy little 115 V / 140 Amp welder by then. But, it gave me a $50 gift coupon at the "big box store" where I bought my measly little welder. From that I got my auto-darkening helmet. If I had it to do all over again, I'd happily make the all same mistakes over again.
No, I'll never weld a D-8 Cat to the bottom of the Brooklyn Bridge with my little welder. But on our 25 acre farmette, with my adolescent little tractors, and all their little Howse and King Kutter tag-along buddies, I'll do OK.
And you want to see smooth? Try shielding gas with flux core wire!
Knute
P.S. I've attached a picture of a baby tractor I had until a couple of weeks ago. I used it for bushogging some nasty overgrown fields with saplings up to 2-inches, and for logging. On the front is a wimpy little bumper I built with my wimply little welder. The wimpy little chain welded to the front pulled out some pretty good size logs. The trailer hitch plate regularly pushed a 4 x 8 trailer that hauled over half-cords of cut and split oak out of the woods. In about a year of aggravating this poor little machine, my bumper never broke or fell off. The bumper is made from 4-inch pipe with 1/4-inch wall.
/ I "need" a welder..? #52
I'm in a similar situation myself.. The thing is that I made my mind up that nothing short of 220 will do... I have a small stick machine that drives me nuts... It will work........OK, on a peice of sheet metal(thin) if I use the higher setting with the smaller rod... If I try to get it to do something(it may have been designed for) it will trip the internal breaker... The DC makes a difference, if you are trying to weld your bucket hooks and it trips as soon as you get it going, it will take forever.. Maybe your more patient, but time is money(even if its your personal stuff) my time is very valuable to me and my family, I dont need to fiddle with something for hours if the right sized machine could do it in 5min.. Thats my personal decision on the matter.. I've even decided on the MM210 or Lincoln equivilant(I hear the lincoln parts are cheaper if it needs repair too).. I'm looking at $1200, still swallowing that and trying to fit it into the budget, but I'm sure it will be worth the wait in the long run as I hate wasting money on something that "might" do what I need..
Something else to think about that concerns me about your posting too.. You keep mentioning bucket hooks.. They need to be solid, a marginal weld on one could kill you or someone else...
Sorry to be a bummer, but you'll be happier in the long run with a larger machine.. Kinda like hunting deer with a .22 .. It can do it, but your much better off with t a 30-06..
/ I "need" a welder..? #53
knute_m said:
On the front is a wimpy little bumper I built with my wimply little welder. .....The bumper is made from 4-inch pipe with 1/4-inch wall.
I think it's fair to say that ( in this thread ) it has been well covered that 1/4" welds ok with 110v welders.
Soundguy
Soundguy
Thats all someone needed to tell me back at the beginning...LOL
Oh..BTW..I DO understand about the "emergency" weld job in the driveway!! Sometimes life's a BI**H aint it! It cant break in the barn..AFTER your finished...lol
/ I "need" a welder..? #55
Only once was I lucky enough to have a failure right at the barn. I was driving my 8n in to the barn, I pulle din, hit the clutch and eased the brake down and as i came to a stop, the steering wheel and about 8" of steering shaft came right outta the top of the steering box!!!.. pretty much right as the tractor stopped moving.... go figure..
Soundguy
Soundguy
LOL..."My luck" is never that good...lol Id break down while going thru a mudhole mired down axle deep...lol
/ I "need" a welder..? #58
Just curious here.. how much $$ is the hobart 110v/140a flux job going for?
Reason i ask is that a lincoln or hobart AC stick welder in the 225a range is about 240$ and will weld anything....
Soundguy
Soundguy
$450-500..depending on where you get it! And your right...Local TSC has that Hobart stick welder for ??..$240-245..somewhere in that range. It would do me..IF...IF.I could use a "stick welder" worth a diddly darn....lol. That why I thought Id ATTEMPT using the wire fed rig. "Supposidly"..?...lots easier to make good looking welds with???
/ I "need" a welder..? #60
Remember.. flux core mig doesn't produce the pristine clean welds of a mig using shielding gas. You do still have to chip some flux and slag.. though not nearly as bad as stick. Add to that you can run a continous bead, instead of striking a new arc every few inches as you change rods.
Still .. with practive.. you can make some darn perty welds on stick.
I buzzed up some foot steps-ups for my allis G, and they look ike they were welded with a mig using gas... I used 1/16 easy strike rods on a 70a setting, and had clean metal to start out with.. was welding 3/16 and 1/4 to a 3/8 crossmember. Nice even beads.. alomst looked like a DC weld... Guess I got lucky that day!!
I think the key to stick is a steady hand.. and practice.. just knowing what the puddle is going to do. Surface conditions and surface prep .. while not as important for penetration with stick, still contribute greatly to the appearance of the weld. No doubt you can make a safe 3/8 to 3/8 weld with a big ac stick if the metal is painted pitted and rusty... but the bead may not look as good as if it was clean 3/8 to 3/8 with nicely ground edges... etc
I'm not trying to influence you one way or the other... besides.. it's not my money. For me.. the cheaper unit would be fine, as i don't mind chipping and grinding a bit if I have to... And every bead i run looks better than the next.. so to speak.. ( but yes.. mig is easier than stick.. though i did learn mig -after- i learned stick.. so that does have some bearing on my opinion..etc )
soundguy
16ft Equipment Trailer (A65579)
16ft Equipment...
2013 FORD F-450XL SUPER DUTY DUMP TRUCK (A64277)
2013 FORD F-450XL...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2022 EZ-GO ELITE...
2015 Isuzu NPR HD Porta John Recovery & Cleaning Truck (A62613)
2015 Isuzu NPR HD...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
