I need a snowblower for my YM146
   / I need a snowblower for my YM146 #1
mikek2
Wisconsin
Yanmar 146, Kubota B6000, Farmall M, SC Case, Ford 3000, International T6
Hi gang! Noob to the forum here. I have a Yanmar YM146 that I just don;t get enough use out of. It is in nice shape, but it doesn't have a rear PTO or 3 pt hitch.
...anyway, I really would like to get a front mount snowblower for the old girl. What are my options? I'm guessing that there is no reliable source for Yanmar made units anymore - is there any John Deere model that will fit?
Thanks!
Mike
   / I need a snowblower for my YM146 #2
Good luck. I looked for a year and a half and had to buy a tractor with one attached to get it...
   / I need a snowblower for my YM146 #3
The rear PTO's can be had. You're in the same boat as the snowblower for the 3 point hitches though.
These tractors do come up for sale from time to time, including on E-bay. Keep your eyes open and you could pick up a parts tractor or donor for less than $1000 with some of the parts you need. Since parts availability for these tractors are limited to begin with, a parts machine is always nice.
   / I need a snowblower for my YM146 #4
Mike, if your mower deck is belt driven, then you have all the front belt driven snow blowers as options. All will surely need to be engineered to fit. Mounting hardware and pulley sizes will be sure things needing attention.
If, however, your mower deck is drive shaft driven, you have fewer options. Obviously the mounting hardware will need to be modified or engineered, but finding a drive shaft with the correct length and possibly with the correct ends might be a problem. You might need a machine shop to get the correct length and matching ends.
None of these are too difficult to achieve if you are at all handy.
Now, after you have your front mounted snow blower working, start planning your cab. you have no idea how much snow blows, until your sitting in the back draft from your blower. Guess how I know. :)
   / I need a snowblower for my YM146 #5
Nothing on the YM146's are shaft driven.
Thanks everybody. I figured I'd probably be doing some fab work . I don;t really have any need for the rear PTO or 3pt on this machine, I only mentioned it to illustrate that a rear mount blowere wouldn't be a viable option for me. I have bigger machines for ground work, but I'd really like to move snow with the Yanmar. It's a really pretty machine and it runs like a top, seems like a shame to just let it sit there.
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
Kubota BX2230D (A47384)
Kubota BX2230D...
2004 Ferrara Pumper Fire Truck (A51692)
2004 Ferrara...
Athey 7-12 Force Feed Loader (A52384)
Athey 7-12 Force...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A53426)
2013 PETERBILT 386...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
