I NEED A SNOW PLOW!! PLEASE HELP
   / I NEED A SNOW PLOW!! PLEASE HELP #1
JohnDeereFan8899
On a farm in Iowa
John Deere 9430T, john deere 4720 cab, john deere 9770 Combine, john deere 8345 R
I have a craftsman tractor. I dont want to buy the sears plow because its cheaply made. I need any plow that will work for my tractor. any suggestions??????
   / I NEED A SNOW PLOW!! PLEASE HELP #2
You did not say what size your Sears tractor was? Usually the manufactures try and match equipment with tractor horsepower and weight. That being said, anything can be fabricated to with your tractor. Could you imagine a small Fisher or Meyers plow hooked up to your tractor? If you could lift it rear tires would be off ground offering no traction.I would stay with the match Sears has for your model and add wheel weights and chains.
DevilDog
Thanks. Looks like a nice plow to me. The sears plow is just to cheap for the plowing that I do. I will invest in this plow. thanks much.
3/16in Plate Steel Sheets (A52377)
3/16in Plate Steel...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52705)
2012 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
