I need a rear seat for an RTV900?
   / I need a rear seat for an RTV900? #1
CumminsLuke
east central Missouri
Can anybody recommend a rear seat for an RTV900? I don't want to break the bank, but I want something nice that at least two people can ride on.
   / I need a rear seat for an RTV900? #2
If you are looking for one that goes in the bed... Look at Jeep Wrangler rear seats. The mounting brackets can be used in the bed. They are easy to get in and out and most are made of a decent water resistant fabric.
   / I need a rear seat for an RTV900? #3
I built one using plywood with 2x4s to strenghten it and added a cupholder in the middle of it.I used some boat seats from basspro.I got the seatbelts out of an old car.Then used some j bolts and turnbuckles to attach it.I did this so i wouldnt have any brackets bolted in the bed it also gives some storage space underneath and its easy in easy out.cost around $120. Hope this helps
   / I need a rear seat for an RTV900? #4
I like it. Simple, safe, easy to build, easy to remove, functional and comfortable.
   / I need a rear seat for an RTV900? #5
i use a mini van seat in my hpx it they come with the seat belts already attached . you can get them at the junk yard for almost free if not free. i get mine for fre out the dump.
   / I need a rear seat for an RTV900? #6
Sounds like you need one of these!
In all seriousness, you said you didn't want to break the bank, and I'll second the idea of using a Jeep seat or something similar that already has seatbelts and is waterproof.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
