I need a cheap PTO shaft cover.
   / I need a cheap PTO shaft cover. #11
Another vote for grease here. Cheap, readily available, and zero rust. But no harm in using a cover unless the shaft is not greased in which case it will rust.
   / I need a cheap PTO shaft cover. #12
I keep mine lubed and capped. My implement end gets a dose of fluid film.
   / I need a cheap PTO shaft cover. #13
My Deere has a nice steel cap that clips in place. It's usually on. I don't use the PTO all that much, and since I DO grease it - it would collect all sorts of dust/dirt. I like the $9 one...
   / I need a cheap PTO shaft cover. #14
it sure makes it nice when it comes time to use the PTO. [...] I've seen the light
This. It can be a real struggle to put these together or get them apart. Any small extra that makes it easier is a good idea.
   / I need a cheap PTO shaft cover. #15
You could also use a piece of foam pipe insulation.
My mid- PTO is rarely used, so that cap is on most of the time and the stub is greased. If the rear stub is going to be open for a while (like winter when I keep the rear blade on for snow duty) then the rear stub gets lubed and covered.
Even in 2007 the JD PTO guards were $15 apiece.
   / I need a cheap PTO shaft cover. #16
I took mine off when I got the tractor and figured it was basically like the film that's all over brand new products, remove this before using. If I recall, it's up on top of my tractor stuff cabinet still... and did it have screws that kept it on?
Are there any caps that have a spring thing like a pto shaft coupler does to pop on and stay on the stub?
   / I need a cheap PTO shaft cover. #17
The hard plastic covers on my JD have holes and slots cut into the base plate that mate up to round "buttons" that protrude from the casting around the PTO stub. You push the base of the cover over the buttons and turn to lock them in place.
   / I need a cheap PTO shaft cover. #18
Is this what you're looking for? These say they're caps for Kubota . . . but since the shafts are all uniform in size, wouldn't these work?
I'm sure you'll grease it up good before the cap goes on.
A day late for me... I just spent the $11 for one from Kubota. The $5 one would work just as well.
   / I need a cheap PTO shaft cover. #19
I like to spray it with fluid film, I have found the tight rubber sleeves just hold moisture for some reason.
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2019 GMC Savana 12ft. Reefer Box Truck (A56858)
2019 GMC Savana...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
NEW HOLLAND H7460 (A58216)
NEW HOLLAND H7460...
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
Ford N Series Tractor (A59814)
Ford N Series...
