I need a bigger trailer
/ I need a bigger trailer
The laws are a little more relaxed around here (or at least less enforced). I don't plan on pulling heavy loads for any long distances or on major highways if I can avoid it. I mainly wanted to get a trailer that will handle whatever I can put on it in the future.
My truck has the 7.3l diesel. I am thinking about trying to find a '99-'03 F-450 or F-550 with a Western Hauler bed to tow with, but my truck should handle the occasional heavy load for a while.
/ I need a bigger trailer #22
lug nut said:
The laws are a little more relaxed around here (or at least less enforced). I don't plan on pulling heavy loads for any long distances or on major highways if I can avoid it. I mainly wanted to get a trailer that will handle whatever I can put on it in the future. My truck has the 7.3l diesel. I am thinking about trying to find a '99-'03 F-450 or F-550 with a Western Hauler bed to tow with, but my truck should handle the occasional heavy load for a while.
Now this is starting to make sense. :) Get a good brake controller and good luck to you! :)
Dougster
The trailer has some goooood brakes on it. Both axles have brakes.
I had my brake controller set to 30% when I first hooked up to the big trailer. When I touched the brake pedal, I was almost thrown into the steering wheel.:eek:
I've found that it works best when the controller is set to 20-25%.
/ I need a bigger trailer #24
lug nut said:
The trailer has some goooood brakes on it. Both axles have brakes. I had my brake controller set to 30% when I first hooked up to the big trailer. When I touched the brake pedal, I was almost thrown into the steering wheel.:eek: I've found that it works best when the controller is set to 20-25%.
Yeah, with a trailer that big, you've got to be careful with those "boost" settings in particular! :D
I've given up on boost settings entirely with my Prodigy and now I only adjust the wheel up or down depending on what I'm towing. Didn't have to do that with my old (smaller bias ply) tires, but with the new, larger radials on the trailers... those trailer brakes can send me flying too! :eek:
Dougster
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2022 EZ-GO ELITE...
NEW ATS-SP100 100 Ton Capacity Shop Press  (A62679)
NEW ATS-SP100 100...
2008 STOUGHTON ZGPVW-535T-SC-AR 53X102 T/A DRY VAN TRAILER (A59914)
2008 STOUGHTON...
