Rotary Cutter I messed up. Need a new PTO shaft.
   / I messed up. Need a new PTO shaft. #1
MF231owner
Massey Ferguson 231
I bought a used Woods 72 off FB and like a dummy raised it too high for the top link setting and busted the PTO shaft. The bottom end (cutter side) may be okay but the tractor side is toast.
Can I buy just the one side or do I need the whole thing? Recommendations on where to buy?
   / I messed up. Need a new PTO shaft. #2
Pictures of what is actually broke??
You can purchase just the parts that you need. Just need
to know the part number or just purchase a new one..
willy
willy
I'll get pictures in a minute. The bush hog side of the pto has the square rod that slips into the tubing on the tractor side pto. The tubing is what shattered.
This is the bush hog end and should be fine once I pull the broken piece out.
The tractor end is completely gutted.
   / I messed up. Need a new PTO shaft. #6
Call these people. Best in the business. They can fix or replace any PTO shaft/issue
After taking it apart and looking it over in the daylight I think I may just have a buddy weld it back together. May may an inch or so shorter but I think it'll be okay.
What do y'all think?
   / I messed up. Need a new PTO shaft. #8
I had to cut one open to retrieve a broken portion of the other side out of it and welded it. I'd cut it some so you have nice strong material and clean edges, then weld away. Looks like someone already has at least once.
Yea I don't believe that bottom weld is by Woods either.
   / I messed up. Need a new PTO shaft. #10
Welding will be fine just keep the U joints in phase and the shaft straight.
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A57024)
NEW 2025 Load...
2018 Ford Transit 350HD Handicapped Van (A53422)
2018 Ford Transit...
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2020 JOHN DEERE 317G SKID STEER (A52707)
2020 JOHN DEERE...
