i messed up i was confused
   / i messed up i was confused #11
PLOWER, gotta have it. Every little bit helps. I've got extremely hilly terrain up here in the green mountains of VT. so every inch of width helps. I run wheel weights too. The real benefit of course is to allow you to use the attachments.
DFB,
Are your tires filled with water too?
PLOWER
   / i messed up i was confused #13
I had the same problem with my 4100 with R4 tires. I reversed the wheels and have had no problem since. The 4100 doesn't have 2 piece rims. It's easy, just jack up the tractor and support with jack stands. Then reverse the left tire to the right side and vise versa. When this is done, the valve stems are facing inward. I now have no problem with rubbing implements and the tractor is more stable too.
   / i messed up i was confused #14
No water, I'm using bolt on wheel weights. Two per wheel. They weigh 60lbs each. That and 20lbs air pressure in each rear tire gives me pretty good traction. If I go to liquid filled I'd use RV anti-freeze. Plain water would freeze.
Thank you all for helping me on this,I will definatly get the tires switched around.
PLOWER
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Year: 2011 Make: Nissan Model: Sentra Vehicle Type: Passenger Car Mileage: 161,039 Plate: Body Ty... (A55853)
Year: 2011 Make...
24640 (A55853)
24640 (A55853)
