Price Check I-Match pricing
/ I-Match pricing #1
Gary_in_Indiana
Elite Member
Fort Wayne, IN
John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
Can anyone give me an idea of what is a fair price to pay for an I-Match for my JD4200? Thanks. /forums/images/graemlins/smile.gif
/ I-Match pricing #2
Gary - I have quotes from $180 to $225. (The $180 was with a $500 box blade) How about you?
/ I-Match pricing #3
I believe MSRP for this item is $220. My dealer was quoting me a sale price of $190. Anything below $200 I'd say is reasonable. I decided to forego this purchase and went instead with the telescoping draft links.
...Bob
/ I-Match pricing
I called my favorite of the two dealers in the county here and was quoted $180, also. I thought that was one heck of a good price on it based only on it being the same money (withing a dollar) of the price my local Tractor Supply has on their (Speedco?) quick hitch.
/ I-Match pricing #5
TSC cat 1 quick release was $149 and $199 for cat 2.. made by speedco..
or at least what the tag said..
/ I-Match pricing
I was looking in the old 2002 Blue Book. There the Cat 1 was $179.48 and Cat 2 was $249.99. I don't have the 2003 Blue Book here.
/ I-Match pricing #7
</font><font color="blue" class="small">( I decided to forego this purchase and went instead with the telescoping draft links.)</font>
Hey Bob,
Could you give me some info on the telescoping draft links?
I have a 2210 and would like this option also. Most of the 4xxx accessories are the same for the 2210. I just have a brush hog that I need to attach and un-attach once a week and these links would work nice. I don't really need a quick hitch just for the one implement.
/ I-Match pricing #8
I got a Speeco at Northern Tool with a discount Cupon for net $150 and it has an adjustable top link. The JD does not adjust and locks you into JD attachments. ALL of them are made by the same company. Check it out carefully before commiting to something that will limit the third party attachments.
PS: My top and tilt really makes the hookup of attachments easy.
JD 4300
JRF
/ I-Match pricing #9
<font color="blue"> "...give me some info on the telescoping draft links..." </font>
See pic attached of my telescoping draft links. The levers on top pop up and the links extend about 4-5 inches. They cost me $207 plus install.
The telescoping links make hitching up your 3PH implements a cinch. Just wiggle these around a bit laterally and outward and they hitch up within minutes to your lower lift pins on the implement. Without them one would likely wrestle around with the implement itself which is a good way to pull your back out. /forums/images/graemlins/crazy.gifI'd highly recommend the purchase of these links.
Not sure if this option is available with the 2210. Check with your dealer. If available, get them. You'll be glad you did.
...Bob
/ I-Match pricing
<font color="blue"> The JD does not adjust and locks you into JD attachments </font>
I was under the impression that the I-Match wasn't limited to JD labeled attachments. Can you explain that to me?
Also, is there any chance you could tell us more about your top and tilt? Is it one you built or bought, etc.?
/ I-Match pricing #11
Thanks rancar -
I had the adjustable links on my old JD2010 utility and like you say, make attachment so much easier. With my little 2210 I never even thought of them. Will be checking with my dealer next week.
/ I-Match pricing #12
I have impliments other than JD that I use on the iMatch without a problem /forums/images/graemlins/grin.gif
/ I-Match pricing #13
My dealer told me the Imatch would work with all true cat. 1 equipment, that has been manufactured in the past few years. Something about the standard being adapted for lower link spacing and top link hight.
/ I-Match pricing #14
The JD IMatch assumes the standard Cat 1 spacing of ~26" between and ~16" up to the top link. My implements vary everywhere from 14" to 21" on the top link with most being within an inch for the lift arms. Also the space under the top link must be clear for at least 4"+ for the top hook to engage. Almost none of my implements have that space.
As I understand it the newer JD attachments all will match but maybe not older ones. Most third party attachments do not have the clearance at the top hook.
I got a Speeco (lot less money)and which has an upper hook that adjusts to fit all my implements. Some require me to get off but with a PTO hookup thats necessary anyway. All in all the quick hitch is a great timesaver over the telescoping links. This is especially true with a top and tilt lift.
JF
/ I-Match pricing
I went and looked at the Speedco with the adjustable top link feature today at TSC. It was $169.99 vs. the $180 I was quoted for the I-Match. Certainly, if I need that, it would be invaluable. Obviously, the ten bucks isn't much of an issue... probably even less so that the color.
The money that is a consideration is the $20 I'd have to spend to equip each implement beyond the first one with Speedco bushings so the implement will be compatible with the speed hitch.
If I put the included pair on my box blade, I have to buy a pair each for my finish mower, rotary cutter, carry all and anticipated trailer mover/boom pole I'm into another eighty bucks (effectively) to buy the Speedco IF the I-Match doesn't require such bushings. If it does require them, then the eighty dollar issue is moot.
Two (more) questions on this now come to mind. Does anyone know if the I-Match needs the aforementioned bushings? How likely am I to need the adjustable top link if all of my implements are no older than a couple of years? I have a First Choice box blade, Woods finish mower, King Kutter rotary cutter, King Kutter tiller and King Kutter carry all. Does anyone have experience matching any of those to either the I-Match or the Speedco? Thanks!
/ I-Match pricing #16
hi Gary
The Imatch also requires a bushing, I paid 10 bucks a pair for the Speedco bushings which work with the Imatch too.
All my attactments are Imatch compatible at this point. My dealer was unable to get me the Imatch for the weekend so loaned me a Speedco hitch, so I've had a chance to try both.
I have a JD lx 4 rotery cutter, frontier BB and frontier land scape rake, the Speedco did not work well with any of em, one attacthment worked with the upper hook, the rest did not, so I was constantly removing the hook and installing the adjustable upper link, it seemed to me the hook did not stick out far enough, the bolts that hold the hook on would hit before the hook would engage. It was not a quick hitch, I spent more time working on attaching implements then using them. The Imatch works as advertised as long as your implements are imatch compatable. In my opinion the time required to remove the hook and install the adjustable link defeats the purpose of a quick hitch, it would be better to modify you implements to fit the the solid hook on the hitch.
later
Phil
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
YALE FORKLIFT (A63291)
2014 International 4300 DuraStar Crew Cab Knapheide Utility Flatbed Truck (A68183)
2014 International...
CAT 980C GP Bucket (A68134)
CAT 980C GP Bucket...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
