I made sure I Wass on solid and level ground
/ I made sure I Wass on solid and level ground #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Even with the L39 ballasted to 8200 Lbs, it was tippy with this pepple.
I have my hydraulic turned up just a bit, and if it were not for the extra weight, I would not carry such a rock.
The L39 barely lifted this rock. I'm guessing 2,500 Lbs. It is about 7 feet across, 42 in wide at the widest point and 14" thick.
/ I made sure I Wass on solid and level ground #2
That grapple looks good with that rock in it! Nice pile of those rascal's in the back ground too.
jb
/ I made sure I Wass on solid and level ground #5
;) Now thar's a pebble that really rocks:D
/ I made sure I Wass on solid and level ground #6
Nice Action Shot!!
Send More..The Little Boy In Me Is Begging!!
/ I made sure I Wass on solid and level ground #7
What brand grapple it that? I want one.
Borgford Grapple, and yes I've had to straighten a few teeth and do some weld repair.
Grapple
FYI Grapple is custom 66" wide and 675 LBS.
The Komatsu Excavator was used to move only 3 Rocks the L39 could not handle.
I load the 4500-5000 Lb Rocks on the front blade and hold it in place with the Hoe bucket.
The Komatsu excavator is 18,000 lbs, but I should have purchased a 15 tonne machine like the CAT in background or even bigger to really handle some of this stuff better. A CAT 385 or Volvo 460 would be the nuts if I could get one for a week. The PC75UU2-E Excavator will not handle any bigger rock than the L39 can carry. By handle, I mean pick up the rock and place it any distance from the machine center of rotation. At full extension out over the side the machine is tippy with +1,000 lb rocks, as the thumb weights over 400 Lbs and the offset boom and ZTR design hurts lifting ability. Over the blade the machine will pick up at full extension just about what the L39 can lift. My point is a mini excavator would be too small to complement a L39, never mind a larger TLB.
So wall building is best done with one ton or smaller rocks.
I am trying to do my best to clean up weekends from the blasting and major excavation going on to finish the foundation frost wall, big dollr 400A underground electrical, drainage, and septic trench lines, way to much of them blasted through darn NH granite. Also we are building this 50' X 28' equipment shed on a 4000 LB mix with fiber 35 yard monolithic slab. The area the slab sits on a 10' deep filled area from some of the material what I had blasted from the home site. The rest of the blasted material was used to build the 1/4 Mile road ino the place.
That little L39 must have move 1/3 of the material for the road. Knock on wood that the hydraulic cushion accumlator seems to be saving the hydraulic pump pushing the little tractor the way I do. I wonder why they are not standard, as factory installed would not add $100 to the cost of the machine.
The hydraulics are only very slighly bouncier, but is that a bad thing? I really don't even notice anymore.
That ASV RC60 beats the L39 in a Drag Race, but the L39 is a leatherman's tool.
I had to blow off for a few hours to take a ride with my buddy. Sometimes you can spend too much time on a tractor.
/ I made sure I Wass on solid and level ground #10
Wow, that's a lot of work, but you sure have a pretty site!
Guess you don't want to hear about my buddy that had a house built and a 50x100 shop and in all the grading, digging for footings and basement the largest rock was less than 5 pounds.
Made the house cheaper!
jb
MarkV said:
Hey Mike, did any dirt come with your place or just rock? :D
MarkV
My best honest guess is 65% rock, 20% Dirt & soil, 15% roots & stumps.
That's why NH is the granite state. The glaciers really stripped awy a lot of soil and moved in a bunch of glacial till. I find ocassional rocks of marble, quartz, and sandstone carried here from who knows 10,000 years ago.
This white pine twig was 40' long, 16" dia on the big end and 11" dia on the othr end. It was a bit lighter than the rock in the previous photos. The rock is one of these posts also.
Construction underway of 28' x 38' equipment shed with 12' x 24' lean-to.
6' 3Pt Disk (A66285)
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
2018 International HX620 Quint Dump (A62613)
2018 International...
Plasma Cutter (A66408)
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
