I lost a post!!
/ I lost a post!! #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I think? in Dec of 02 till the first part of 03 I had posted my cab I made for my 4400. I have searched hi and low. I can not find it any where. I know it was in this form (i think) that was before build it your self was here.
I got a virus and crashed my computer, so I lost all the pics of it. I would just like to keep the orginals if I could. Thanks to any one that can point me in the right area!!!
DDT
/ I lost a post!! #2
I wondered if I possibly had downloaded any, and found two (I think they are yours) and will send them, just in case it helps.
/ I lost a post!! #3
This is the other that I have.
/ I lost a post!!
That is her.
I don't suppose we could find the post.
/ I lost a post!! #5
I thought you had already looked at your posts, but thought I would for kicks.
I found this.
Cab in Progress
/ I lost a post!! #6
DDT. If you ever need to find one of your posts again, just click on your name and then on "show all user's posts." You should be able to find it if you have an idea of when you posted and the subject. Of course, many changes have occurred since you made the original post, and maybe it's not on that list any more?
I wanted to ask if you ever made a heater for it. I was worried about your use of the engine heat as you may be getting too much carbon monoxide that way. You blood attracts carbon dioxide even easier than oxygen and it doesn't take a lot to cause you harm. Just a thought on your safety. John
/ I lost a post!!
That is it. I sure could not locate it. Thanks beenthere.
KiotiJohn, thanks for the tip, I guess that would be the easy way to do it, since I now how now!
I am still useing engine heat, most of the time I have my coats & gloves off. There is no carbon monoxide in the cab that I now off. I don't feel tierd, eyes don't burn so I think I am OK. As long as I don't have any exhast leaks. Now if the wind is wrong and I leave the door open when I get out, that is another story.
I did have the glass tinted last fall before I put it on for the winter. Much Better.
/ I lost a post!! #8
John, I think that is a diesel and diesels don't emit carbon monoxide fumes.
Michael
/ I lost a post!!
)</font>
I learned some thing today. Thanks Michael
/ I lost a post!! #10
</font><font color="blue" class="small">( John, I think that is a diesel and diesels don't emit carbon monoxide fumes.
Michael )</font>
Diesels and CO
Michael, this is a common misconception, and I have no idea why it ever got started. While diesels put out LESS CO than do gas engines, they still emit CO. CO is the byproduct of any internal combustion. Check out the article link to see more. John
/ I lost a post!! #11
Thanks for that info John, and now I've learned something. I have always thought diesel exhaust was free of carbon monoxide! I am a retired trucker and now think about all the nights I have slept in an old truck with a leaky exhaust system. All truckers have done it and I have never known of a problem. I guess there is just enough space between the cab and frame to dilute the fumes. I remember some years back a couple was found here localy in their VW van that died when they went to sleep with the gas engine running. Thanks for the info.
Michael
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2009 FORD E-150 CARGO VAN (A66091)
2009 FORD E-150...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
7'x18' Truck Flatbed (A64912)
7'x18' Truck...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
