I Learned a Valuable lesson last night!!
   / I Learned a Valuable lesson last night!! #31
I trust my lever actuated 4wd and don't know if i want to rely on a selenoid and wiring to holding me back on a hillside. Maybe the system fails to 4wd but I would bet it is the other way around. Does the electric engagement type stay locked when the tractor is turned off? Surely so because otherwise the parking brake would just be the back wheels. I always lock mine when trailering too.
   / I Learned a Valuable lesson last night!! #33
James, I'll bet that if you have HST then this contributes to the quick slow down as well. At least my tractor comes to a quick stop when going into neutral.
Yes, mine too, almost like hitting the brakes.. and if you are in 2WD, going down a steep slope and yank your foot off of the forward pedal rapidly it can start a slide of the rear wheels unless you have a lot of weight on the back. With a hydro, you rarely ever have to use the brakes. Just to prevent "drifting" when stopped on a slope. Even then if you want, you can just give the hydro a little reverse direction pedal instead of stepping on the brakes and it will hold it still.
   / I Learned a Valuable lesson last night!! #34
That is a very good question.
   / I Learned a Valuable lesson last night!! #35
I think mine stays locked when in 4 WD as long as the switch is not flipped to 2 WD. As soon as you turn on the key after it has been parked for a while, the 4 WD indicator light comes on if it was in 4 WD when parked. You can flip the selector switch prior to cranking it as hear and fell the 4 WD disconnecting. You can tell that the front tires are somewhat in a bind when it disconnects as there is a definite popping noise as the gears disengage.
I think it would be easier on the tractors when disengaging the front wheels to stop, backup a few feet and then disengage. I have to do this with my RTV 900 to get the gear lever to move. I just apply a bit of pressure and back up till it slips out of 4 WD. As most folks know, the front wheels are always pulling a bit ahead of the rear. I can see signs of this in the wearing of the tread in the front wheels on both my tractors especially the B26 that is always in 4 WD unless I am travelling on a highway.
   / I Learned a Valuable lesson last night!! #36
And Nukes... :D
This is also a good way to check if you're Really in 4WD.
On gravel, goose the throttle and then hit the brakes (pedals locked).
The front wheels will skid along with the rear.
Kudos to Dave @ Daves Tractors for this tidbit, I wasn't sure my 4WD was engaging.
No you don't have to be close with a nuke!
   / I Learned a Valuable lesson last night!! #37
Ah yes, the infamous "2 inch ride"!
You suck up two inches of seat cushion until you get it back under control.
I'm a charter member of the club. Welcome to the club!
   / I Learned a Valuable lesson last night!! #38
Never take mine out of 4 wheel drive anymore except on the road - had that same experience once and really never want to repeat it!
   / I Learned a Valuable lesson last night!! #39
I'm curious as I never had any slides with my old TO-20 Ferguson in 20 years of nothing but 2WD . I feel like I'm missing out on something important here since I just got a 4x4 Massey. I only put 55 hours on the new one so far but rarely use the 4WD. By any chance were those R4 tires you guys were sliding with? I heard from other guys about them being infamous sliders in mud . That's why I insisted on farm tires with their rough ride and tendency to tear up the lawn.
I did do a real nice slide in my old truck 5 years back after an ice storm. I had it parked on a tiny hill beside the house like I had for years. No prob till I started it up and tried to move and sideways i went. Forward, nothing, reverse nothing , switch to 4wd nothing. Right through the fence in slow motion and would have been ok but for my daughters horse hitching post I had sunk 18" in the frozen ground. Got the pax door and all down the side of the box in one long creeping scrape. Ah the perils of street tires on ice .:confused
   / I Learned a Valuable lesson last night!! #40
I Learned a Valuable lesson last night. It's that time of year up North so I decided to unhook my rear finish mower for the season. I took it up the hill to a storage garage and put it away. Now my little tractor has no weight on the back and an empty bucket up front. Not thinking anything about it, I drove the tractor back down the fairly steep hill to the house. The Tractor was in 2 wheel drive and as soon as I hit the steep part (about 7pm, with just a start of dew on the grass) the rear wheels lost traction and away I went down the hill FAST, really FAST. I dropped the bucket down on the grass to slow me to a stop, and then I tried to figure out what heck just happened. A combination of no brakes on the front wheels and being in 2 wheel drive, meant I had no stopping power up front were the weight was. Once I figured this out and checked my shorts! I tried the hill again, this time in 4 wheel drive. No problems, I even stopped part way down the hill and backed up. A simple thing, but this could have been a really bad accident had I hit the brakes hard and the tractor spun sideways or even rolled over. Moral of the story, steep hills up or down = Tractor in 4 Wheel drive. I hope this can be a useful tip to someone!!! As usual one Man's Stupidity is another Man's Wisdom!!
A few years back I had my Kioti DK40 (loaded R4 tires)with my 6ft finish mower on a slight hill with wet grass and away I went down the hill as I tried to drop my front loader on the ground to keep from tipping over.Scared the crap out of me.Heck of a pucker factor on my tractor seat.Glad to hear you are ok and nothing worse happened.
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56435)
2012 MACK Tender...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Heavy Duty Skid Steer Post Driver (New/Unused)(Est. Retail Value $4,900). (A59225)
Heavy Duty Skid...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
