I knew it!
   / I knew it! #1
daTeacha
Veteran Member
Funk, Ohio
Somehow I knew from the title that Doc Bob's thread would be closed. I was surprized you guys kept it acceptable as long as you did. :)
   / I knew it! #2
It was funny:D
   / I knew it! #5
My apologies for any offense I may have caused. I have reposted using the words "loose devices". I still need help on how to correctly adjust the "loose devices".
Bob
   / I knew it! #6
Bob
Doc Bob,
Geeze. We accept your apolgies for such a grave offense. But, now how do we answer your question without using offensive terminology?
Oh well, here goes --
I see two simple fixes.
One is to use NYLON INSERT LOCKNUTs. Any reasonable hardware store will have them. The nut is metal, the threads are nylon. They take a little effort to get on a rod as long as your throttle linkage, but they won't move once you get them installed. You could replace both nuts, or you could just tighten one of these locknuts against the nut on the open end of the rod.
Another solution would be to use Loctite thread locking adhesive. Again, most any reasonable hardware store, or automotive parts store, will have
Loctite Red 271. There are several Loctite thread locking forumulas, but this is the most popular and the easiest to find. Before you tighten the nuts into position, apply a few drops of Loctite onto the rod threads. Then tighten the nuts into place. They should stay.
Good luck,
Knute
   / I knew it! #7
I'm surprised there were not pal nuts installed.
Soundguy
   / I knew it! #8
Soundguy
What are PAL nuts? What does PAL stand for?
Bob
   / I knew it! #9
knute_m said:
Doc Bob,
Knute
I will get some Red 271.
Thanks.
Bob
   / I knew it! #10
Bob
A retaining nut. I guess a jamb nut might be more applicable in this setup.
Soundguy
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2014 MACK GU713 DAYCAB (A53843)
2014 MACK GU713...
