I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd Fld
   / I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd Fld #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Mowed 30 mins & it's leaking 1/8" solid stream of Hyd fld from under Hyd Filter.
Filter was so loose I turned it with 3 fingers. I tightened it & it's still pouring.
I'll call dealer in am & remove filter for a look see.
Man I Love the mower & it's cut with the Rear Discharge.
I've been mowing with rear finishing mower behind a JD tractor since 2001 with RD.
   / I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd Fld #3
Re: I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd
Looks great and good choice. Our 60"R should be in at the end of the week or first of next. Hopefully they will get the hyd leak found and fixed quick
Brett
I sure like the 7" Wider front axle on the 72" :D
Mine has 8" front rims like the ZD1511 comes with.
All the ZD1211 I've seen has the 6" front rims, of coarse both are 15" height size though.
   / I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd Fld #5
Man, that's a fricking monster mower. I hope you have a lot of lawn, cause that thing will go nuts without a job. LOL.
LoL, it's a baby compared to my 66hp JD 4720 Hydro & Befco 110" RFM.
I mow 7r8hrs a week on my Farm.
   / I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd Fld #7
I wish I had gotten the rear discharge deck. They did not have a ZD1211 60" in stock and the only one they could find close was side discharge. I didn't want to wait for one to be ordered. With the power it throws out quite a cloud of clippings and dust. If the wind is blowing I have to make sure the discharge is downwind.
I can feel this line in the sealing surface with my fingernail.
I hope it ain't a crack.
I'm headed to get a new filter but o ring on original one looked fine.
   / I just unloaded my new ZD1211RL-72R rear discharge mower tonight& it's pourin Hyd Fld #9
You zoom in on that pic and it looks like the whole raised top area has hairline cracks showing up around the port.
Or maybe I am just seeing too much. Check it out.
Those are swirl marks from the machining process.
New filter DIDN'T fix the leak.
I cleaned & watched with a mirror & flashlight while running.
The O ring on steel line right beside front Hyd Filter, was pinched & wasn't seated into recessed hole.
I replaced O ring & barely bent line to push it firmer into the hole on trans.
Bingo - I've mowed 1.5hrs w it & Absolutely Love it.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
