Chipper I just scored a Goossen Chipper...
   / I just scored a Goossen Chipper... #1
Scott in IN
Indiana
Kubota L3400
I just picked up a Goossen Chipper and Blower (after a friend noticed it along the side of the road with a "For Sale" sign) for $500. Once it was home I lubed up the bearings, reattached one of the plastic curtains and fired it up.
It shredded OK but the chipping wasn't so good. I checked out the manual and found that I probably had some dull knives. So I took the whole thing apart (which was necessary due to the blower) and found that one knife was broke in half and another was gouged pretty good.
Great... A new set of knives is around $127 so I asked my neighbor guy (who is a tool and die maker) if he could make me a knife. He said that he could (for free as I plow him out in the winter) but he'd have to use an oil hardening steel and it looked the original knives were made with high speed air hardening steel (A1 I think he said). Anyone see a problem with this and/or know where to get a cheaper set?
Lastly I'm missing two guards, part numbers:
#9 "Belt shield back"
#17 "PTO front belt shield"
As I want to get these replaced before I rip off an arm or something, can anyone measure theirs and post a picture of them so I can get the local sheet metal shop to make me up a set?
Thanks,
Scott
   / I just scored a Goossen Chipper... #2
I'll bet you can contact them and they can help you with the parts. Chipper Shredder By the way, this chipper is recommended for use with 18 to 25 HP max output. You didn't mention what you are using to power it up.
   / I just scored a Goossen Chipper... #3
Personally, if you got that for that price and it runs mine, I think I could live with the 127 dollars more to make it top notch.
Can the knives be sharpened at all, for spares or use when you would chip or shred stuff that would be more abrasive?
I've got a Kubota L3400, I just updated my signature.
As far as the knives yes they can be sharpened. I think I'm going to run it with the oil hardened knife made by the tool maker and see what happens. Worst case I'll order another set.
However, I still need pictures and dimensions of the guards...
   / I just scored a Goossen Chipper... #5
You got a steal! I have always thought that the Goossen looks very similar to the Bearcat 554/70554 which is identical to the Woods 5000. Maybe the blades are the same. A funny thing that I have found is that the Woods parts are a little cheaper than the Bearcat. That may just be the different dealers. I would rather use the factory parts. I keep 2 sets so I always have a sharp set. My Bearcat 554 works best for the first hour of newly sharpened blades. I get maybe 10 hours. sometimes I can push it to 15. On my machine there are 4 blades. 2 inside and 2 outside and you can switch them to get a little more blade life. Mine are held in by grade 8 bolts which are secured with blue Locktite. The Bearcat site has pdf files of the manuals which include the parts diagrams. There have been a number of posts about this type of chipper/shreader here. It might be worth some time to go back and check them out.
Chris
Well, I finally got the new blade installed and the thing all put back together and all lubed up. I'm still working on the guard issue, which a friend is going to help me out with on the use of his brake.
Anyhow, I've noticed a number of "Tree of Heavens" around the place which are real bad news. Wanting to play with the chipper, I whacked the invading trees down with the chainsaw and then ground up anything under 2" in the chipper (over 2" goes in the wood stove, BTUs are BTUs). I then painted the stumps with "Supper Roundup" which kills the roots. The chipper ran great with the new blade, in fact I had to watch it or it would pull the wood in too fast causing the tractor to bog down. The shredder feature was great too as what I couldn't chip I just tossed in the top and it was soon reduced to chip/mulch.
It's some of the best money I've spent, if you are on the fence by all means get one. Chips are way nicer than big ol piles of ugly brush...
   / I just scored a Goossen Chipper... #8
Listen to your Tool & Die Maker friend! These guys are highly knowledgable.
The O1 Blade should hold up just fine.
   / I just scored a Goossen Chipper... #9
Scott,
I have the same chipper minus the blower. If you still need some pix of the guards I can post some in a day or two. There are two or three pieces that cover the belt, pillow blocks and all. The company was bought by or merged with Harper Industries. If you do a search on Harper/Goossen they still make the exact same product and I'm sure the safety guards (and everything else) are available from them. Let me know and BE SAFE!!!! The guy I bought the chipper from "lost" 2.5 fingers in the machine!
My tractor is only 21hp an I thought it was due to the small engine size that it gets bogged down when I just drop a piece of wood in the hopper. The effort is not the feeding of the wood but having to hold back the larger pieces.
   / I just scored a Goossen Chipper... #10
I also have this chipper in the bushhog brand variety. No blower on mine. You got a great deal on that. A new blower alone is like $1300. I bought a second set of blades for mine. Price was painful. I love the shredder. Eats up anything up to about 1". My 25 hp Kioti only bogs down on big 5" branches in the chipper.
The manual can be downloaded from the harper/goossen website. I think there are diagrams of the sheet metal in the manual too. I will also try to get some dimensions for you. But, it seems to me that there is a great deal of lead-way in the fit of these parts. Should be just as easy to take a few measurements from off the machine for fit and clearance. Make sure you cut some holes to access the grease fittings. The original covers aren't so good with that.
Like easygo says, be careful with it. Don't over load it. Always use a tool to clear and wear glasses and hearing protection at all times.
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
SLIDE MASTER ALUMINUM SLIDES (A54757)
SLIDE MASTER...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
