I hope I can prevent this from happening to other operators.
   / I hope I can prevent this from happening to other operators. #11
Wow, that's gonna slow you down. Hopefully the better half can cover for you for a while. Every time I read something like this, I think that I have been blessed with no serious issues but my day is coming.
   / I hope I can prevent this from happening to other operators. #12
Godspeed on your recovery...
   / I hope I can prevent this from happening to other operators. #13
Yikes! Glad you're still on this side to tell the tale ! TBN is quite the resource for these close calls to act as a warning to us all ! We should have a way to reach out to the members closest in a case like this to help out while a brother is down and out ! Get well soon !
   / I hope I can prevent this from happening to other operators. #14
The end of our "shift" is the most dangerous I think
Glad you here to tell your tale. Heal well 😔
   / I hope I can prevent this from happening to other operators. #15
Thanking God for another chance
At some point I need to publish my 7 rules of gun safety also
Quite the story, here's hoping for a quick recovery back to normal.
How did your tlb make out?
It is a modified 2005 Kubota L39. Other than a weak front axle, it punches to a utility tractor level. The motor is turned up to 45 hp, it is reinforced and ballasted to over 4 tons. I have installed larger loader cylinders and hydraulics that run at 3000 PSI.
So the tractor was sitting at the bottom of the embankment, bucket pointing to the sky, while the back hoe was buried in Some 4-7" trees. My wife told me my son in law got in the tractor, and fully extended the stabilizers and anchored the bucket. He used the hoe to rip out the trees. He then used the bucket, stabilizers and hoe the get the tractor off the embankment. He worked the tractor through the woods, knocking down whatever small trees that were in the way and parked it in the equipment building. I need to check the lights and hoses, but their seems no damage!
I wish I just let it roll away, and got away from the machine.
This winter my stepson slid off the road plowing snow into a drainage ditch and must of paid attention watching me use the hoe and stabilizers to extracate the machine.
Has anyone ever watched the JCB YouTube videos of the dancing backhoes? I have moved my backhoe over walls. Don't try this at home.
   / I hope I can prevent this from happening to other operators. #18
OUCH, that's a heavy load, and I imagine a long time healing.
Did you do anything special on your "anniversary" May 20?
No but I will visit my parents and brothers grave soon.
(1) Multi-Trunked Non Fruiting Olive Tree w/ Military Barrel (A59225)
(1) Multi-Trunked...
Caterpillar 259D (A57148)
Caterpillar 259D...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
HUSQVARNA RIDING...
CLUB CAR  CARRYALL 6 (A58214)
CLUB CAR CARRYALL...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
