I hit my flagpole with my front-end loader
   / I hit my flagpole with my front-end loader #21
Mine got bent under similar circumstances. The single point of contact methods will dent the pole. I filled it with sand and parked it on some soft grass. Then I drove on the high spot with my front truck wheel. It got most of the bend out of it. To make it look ok and keep the flag flying, I stuck an iron pipe in the ground recepticle and pushed it to a small angle. This canceled the remaining lean. Now the pole is vertical at flag height and the kink/offset is at ground level and considered to be a 'feature'. Mine is a 35' tapered aluminum pole ($2000) so simply replacing it with a new one and hiding the damage to the gift was not a realistic option!
   / I hit my flagpole with my front-end loader #22
I would reset the footing in the ground to compensate for the bend. You'd have a one of a kind flag pole with a lot of character! :D....and I'm sure it would be a great conversation piece(probably already is?). Put some landscaping around the pole so you don't accidently hit it again. Put a schrub on either side of the pole and groom them to follow the bend in the pole. :rolleyes:
Don :)
Thanks, for all the suggestions. I am planning on fixing it this weekend. So I'll let everyone know how I make out. Thanks again, eddy622611
   / I hit my flagpole with my front-end loader #24
What? no pictures of the blunder ?;)
   / I hit my flagpole with my front-end loader #25
eddy, Could you get someone to turn a wood plug on a lathe & drive it into the pipe? MikeD74T
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
LOT: Steel Work Table 36" x 72" w/8" Craftsman Grinder, (2) Lockers (VISE NOT INCLUDED) (A59076)
LOT: Steel Work...
2019 FORD E350 16FT BOX TRUCK (A58018)
2019 FORD E350...
PALLET OF MISC PLYWOOD (A58374)
PALLET OF MISC...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
