I have some jd 420 questions (with pics)
   / I have some jd 420 questions (with pics) #1
OutbackL130
chickamauga
L130, 420
I'm in the process of restoring my first tractor which I picked up in rough shape. I've fixed most of the issues and have these remaining ones.
- The hydro pump started leaking badly. Can I fix it without removing from the tractor?
- Where does this stray wire go?
Thanks!!
As far as the hydro leak goes I am looking at the diagram trying to figure which parts to order. To stop the leak do I need #18 M85508 Seal and #14 M45375 O-Ring. Is there nothing else needed?
   / I have some jd 420 questions (with pics) #3
16 can come off to replace that bushing and the o-ring, no big deal. Just gotta pull the driveshaft and the tins. 5 minute repair once the fender pan is off.
If you can you're better off replacing anything thats easier to get to, if you're going to be in there. Save you a trip, like replacing a water pump with a timing belt on a car.
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
FUEL TANK (A50854)
FUEL TANK (A50854)
John Deere MegaWide 567 5x6 Round Baler (A51039)
John Deere...
