I have some jd 420 questions (with pics)
   / I have some jd 420 questions (with pics) #1
OutbackL130
chickamauga
L130, 420
I'm in the process of restoring my first tractor which I picked up in rough shape. I've fixed most of the issues and have these remaining ones.
- The hydro pump started leaking badly. Can I fix it without removing from the tractor?
- Where does this stray wire go?
Thanks!!
As far as the hydro leak goes I am looking at the diagram trying to figure which parts to order. To stop the leak do I need #18 M85508 Seal and #14 M45375 O-Ring. Is there nothing else needed?
   / I have some jd 420 questions (with pics) #3
16 can come off to replace that bushing and the o-ring, no big deal. Just gotta pull the driveshaft and the tins. 5 minute repair once the fender pan is off.
If you can you're better off replacing anything thats easier to get to, if you're going to be in there. Save you a trip, like replacing a water pump with a timing belt on a car.
LOT LOCATIONS (A51222)
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
