I have a water leak to or at my yard hydrant
   / I have a water leak to or at my yard hydrant #31
My brother got a government subsidy to run rigid white PVC in ground to his pastures. This causes me to think it met code for that purpose.
Building codes stop 5' outside the building line. OK, your septic needs to be 10' outside the building line.
   / I have a water leak to or at my yard hydrant #32
Hydrants should not be connected to PVC. The stress of valve operations will crack the PVC or joint. I just dug one out at my place. The last 5' minimum should run in rigid metal, like copper.
   / I have a water leak to or at my yard hydrant #33
A 5ft stick would be even better but I always use these fittings to join pvc to hydrants or meters and I’ve never had a problem with them.
And just maybe that is what happened. Will be a fall project. Will see if you win the prize! Thanks Larry.
Just sitting here thinking that I put a metal 90 and lead in for stability. I did pour a 2' circle of concrete around the hydrant. That I can see, the rest I'm not so sure of anymore. . .
   / I have a water leak to or at my yard hydrant #36
You have my sympathies. There are more than a few projects around here that I have that I wish I had taken a few more photos of at the time.
Good luck!
   / I have a water leak to or at my yard hydrant #37
Photo technology has come a looooonnnnggggg way in the 40 years of my home building process…..
   / I have a water leak to or at my yard hydrant #38
(y)(y)Exactly! And I forget what a great photographic recorder I have in my pocket...
   / I have a water leak to or at my yard hydrant #39
I don’t know why people hold copper in such high regards. I’d rather have pex any day. The upfront cost is much lower, if it does leak it’s a lot easier to fix, it’s more freeze resistant and the copper gets leaks from corrosion all the time. Also unskilled plumbers will connect copper to galvanized fittings that causes corrosion. Pex is hard to screw up.
Didn't use a dielectic union?
   / I have a water leak to or at my yard hydrant #40
The previous owner here didn't. All copper in the crawl space, and all risers galvanized. Let's just say perhaps plumbing wasn't an expertise.
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
90018 (A48082)
90018 (A48082)
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2019 Cat D5K2 LGP Dozer (RIDE AND DRIVE) (A50774)
2019 Cat D5K2 LGP...
