3-Point Hitch I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it?
   / I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it? #1
Hopewell
New Holland TN70
   / I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it? #2
Can you follow the lever all the way down? Usually there are some friction washers there along with a big spring and two studs with nuts. By adjusting these nuts, you can adjust the friction on the lever.
   / I have a TN70 and the position control lever is stuck. It wont move up or down. Any suggestions on how to fix it? #3
This or the cable from the lever to the control is rusted and needs to be replaced
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2025 Electric Diesel Fuel Pump with Hose Reel (A55852)
2025 Electric...
20702 (A51694)
20702 (A51694)
Year: 2017 Make: Mitsubishi Model: Outlander Vehicle Type: Multipurpose Vehicle (MPV) Mileage: (A56859)
Year: 2017 Make...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
