Rotary Cutter i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's?
   / i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's? #1
Bruceybeaver
Houston, TX
Bobcat S300
Anyone have a good cutting option for 8" material? Any feed back or idea's would be great.
   / i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's? #2
   / i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's? #3
Re: i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any ide
Eco mulcher
   / i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's? #4
What is the output of your hydraulic pump?
   / i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's? #5
If it's a high flow it's probably around 35-40GPM, even so using it to cut 8" trees doesn't seem right. I'd figure 3-4".....maybe and even then I would want to do it all the time.....Mike
   / i have a S300 HF Bobcat, Need a heavy Duty Rotary brush cutter to cut 8". Any idea's? #6
You need to post in Land Clearing forum, they can help you with mulching heads.
John
Hi Jeff9366,
Thanks for your reply. I was thinking between $9000.00 & $11,000.00. Problem with the brown cutter is you can't drive up to a tree and bring it down.
Great suggestion but, Thanks
Great thanks John.
Eco Mulcher looks crapy, but seems to do a good job in the video. Whats the pricing?
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
John Deere X530 Mower (A51573)
John Deere X530...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2024 JOHN DEERE 4044M LOT IDENTIFIER 62 (A53084)
2024 JOHN DEERE...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
