I have a problem with my 455 Deere mower.
   / I have a problem with my 455 Deere mower. #1
John Deere 55
About ten days ago I was mowing my yard when my Deere died. I saw that the battery had shifted. I put if back in place and closed the front, but when it started it made a whirring noise that shouldn't be there. So right now the front stays open. Anyone know the problem?
   / I have a problem with my 455 Deere mower. #2
Is the battery in contact with the engine flywheel to make the whirring noise?
There should be a hold-down clamp on the battery (I use a bungie cord to hold mine down).
I don't understand why the Deere died because the battery shifted. Was a cable loose or corroded ??
No. The tractor shook so badly that the battery came unhooked.
   / I have a problem with my 455 Deere mower. #4
Then I'm not sure what the problem is?
   / I have a problem with my 455 Deere mower. #5
I think I'd consider taking the mower deck off and start up the tractor and see if the noise is still there.
I'll take the deck off and see if it stops. If that is the problem, the how do I fix it?
   / I have a problem with my 455 Deere mower. #7
I,ve got the same tractor. And I,m very familiar with how it works.
Is there something rubbing on the flywheel behind the battery ?
You say it shook so bad that it unhooked the battery ? I cann,t imagine how that would be possible, if both the battery cables were tight on the posts. Did the battery fall out of the battery box ? Please let us know what you find.
   / I have a problem with my 455 Deere mower. #8
The mower died most likely because you shorted out the battery to the frame.
Does leaving the lid open a bit stop the sound? Then it's not the deck, but something up top, like a fan. When it's running slowly push the lid down until it starts making the sound. You should be able to isolate it's location. And look for damage from when the battery shifted.
By the way, if it shakes so much at WOT that the battery is jumping around, you've got bigger problems than a whirring sound.
Ok guys I took a day off and took the Deere apart and you'll never guess what I found- a freakin nest of some sort, maybe a squirrel. It was fine until the battery shifted and it fell and thats why it made the whirring noise. I think I'll go by some ammo for my gun... No more squirrels!
   / I have a problem with my 455 Deere mower. #10
Truly puzzling, in several ways. :)
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2001 New Holland EC215 Hydraulic Excavator (A52377)
2001 New Holland...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
