I have a ford 600, the distributor is stuck wont turn or come out.
   / I have a ford 600, the distributor is stuck wont turn or come out. #1
lostbit
ford 600, kubota 2680
Does anyone know how I can free my frozen or stuck distributor?
   / I have a ford 600, the distributor is stuck wont turn or come out. #2
There is an o'ring seal on the distributor flange below the hold down bolt. With the distibutor hold down clamp and bolt removed, keep trying to rotate the distributor. Once you get some rotating movement, start trying to pull the distributor up and out. Any reason in particular you are trying to remove the distributor?
The timing needs to be adjusted, it looks like its set for 2 degrees, that was my goal. It is not turning.
This morning I removed the hold down clamps and added liquid wrench. I will see if that works.
Thanks for your reply.
   / I have a ford 600, the distributor is stuck wont turn or come out. #4
Just have to get distributor to rotate to adjust timing, to need to remove it. If you remove it, you will have to mark both the distributor housing and the rotor positon to install correctly. Is the small clip still in place above the dust cover under your distributor cap? The clip is easy to miss place when removing the dust cover.
   / I have a ford 600, the distributor is stuck wont turn or come out. #5
Ongoing shots of Liquid Wrench then light taps in alternating directions and patience.
I was able to get it loose, several applications of Liquid Wrench and tapping.
Thank you
   / I have a ford 600, the distributor is stuck wont turn or come out. #7
:thumbsup: Great! You might apply a coat of grease when you reassemble.
Already cleaned and greased it.
Thanks.
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
