I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #1
bruce 680
680 case backhoe
I have a case 680 backhoe the hoe part just swings freely you can push it side to side by hand
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #2
Are you asking if this is correct?
Does everything else work correctly?
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #3
Do the swing cylinders work under power via the control valve? If not likely a valve body issue or open check valve in the return line
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #4
Bruce, we need a little more info. It could be a couple of simple things.
Does it swing under power? With full power? will the swing side-push against a pile hard enough to slide the tractor?
What about swinging "uphill" with only one outrigger down? Try both ways.
What do you suspect? What happened right before the swing change?
Are you a mechanical type person with manuals?
rScotty
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #5
Did you check to see if "swing" cylinder(s) is still connected?
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
