I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #1
bruce 680
680 case backhoe
I have a case 680 backhoe the hoe part just swings freely you can push it side to side by hand
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #2
Are you asking if this is correct?
Does everything else work correctly?
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #3
Do the swing cylinders work under power via the control valve? If not likely a valve body issue or open check valve in the return line
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #4
Bruce, we need a little more info. It could be a couple of simple things.
Does it swing under power? With full power? will the swing side-push against a pile hard enough to slide the tractor?
What about swinging "uphill" with only one outrigger down? Try both ways.
What do you suspect? What happened right before the swing change?
Are you a mechanical type person with manuals?
rScotty
   / I have a case 680 backhoe the backhoe part just freely swings around you can push it by hand from side to side #5
Did you check to see if "swing" cylinder(s) is still connected?
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
