I have a Allis Chalmers 170 that is leaking oil into the water and vs.
   / I have a Allis Chalmers 170 that is leaking oil into the water and vs. #1
danielhorst
dickerson, MD
Allis Chalmers 170
My Allis Chalmers 170 is leaking water into the oil and oil into the water. the block has a freeze crack in it from when the previous owner had it. I put a new head gasket in it and I also put radiator stop leak in. that stopped the leak in the side of the engine block and it stopped leaking water into the oil for a wile but now the internal leak has started again. dose any one have any suggestions for what i could do or what the problem might be.
   / I have a Allis Chalmers 170 that is leaking oil into the water and vs. #2
Hi. Welcome.
The freeze crack appears to be more serious than the stop leak can handle. You will have to find where the leak is to determine if repair is possible. This may require a tear down to find.
Others on here may have more experience with this type of leak.
   / I have a Allis Chalmers 170 that is leaking oil into the water and vs. #3
Does 170 have same 226 cu in 4 cyl that d17 had? Those engines used wet sleeves. The sleeve is sealed to block with an Oring on bottom and permatex sealant.
It has a Perkins 4.236 236 cu in 4 cyl in it.
thanks
`Daniel
100 gal Water Tank (A50515)
100 gal Water Tank...
Genie GTH-844 (A50120)
2005 Hummer H2 4WD SUV (A50324)
2005 Hummer H2 4WD...
Swict 7' Fork Extensions (A50121)
Swict 7' Fork...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Steel Flatbed (A50515)
