I Hate Computers
   / I Hate Computers #71
SHF, it is not just limited to increasing the clock cycles, as all chip makers have been doing that, but AMD's theory is/was shortening the imbedded coding to allow the cpu to process the command faster...the shortcoming in my opinion was the fact that it would take 2 or 3 of the instruction set commands to do the same job that the original longer command was able to accomplish.
Do not get me wrong, AMD has put out a very reliable chip, it just generates more heat, and is a little more picky when it comes to cooling it down.
By the way, I don't want to be around when you add the NOX to an old engine! /w3tcompact/icons/laugh.gif You may get a big surprise!
Bird, if you will look at my post above, you will see the url for Sisoft. The program is ok, but I haven't run a comparison on the temps to verify how accurate they are. It definately can and will be an asset when it comes to maximizing the potential of your system...they just don't give you a hint on where/how you are supposed to make the optomization corrections! This can be a real problem for those not up on the tricks/etc of 98 or ME.
   / I Hate Computers
Scruffy, don't know how I missed that./w3tcompact/icons/crazy.gif
Bird
   / I Hate Computers #73
Bird, I usually tell myself "if that's all I miss in life, I'm in good shape"! That is normally good for a belly chuckle, but it's hard to remember what I missed! /w3tcompact/icons/laugh.gif
   / I Hate Computers
Scruffy, it's been so long ago that I couldn't remember what I paid for Sandra, and I've wondered whether I wanted to download it in the new computer when it gets here. I guess I will. I hope that Dell computer is more reliable than Dell's "order status" board. They showed the computer system to be ready for shipment the night of the 15th to be picked up by the carrier the "next business day" and ever since then it simply shows "In Transit to Local Carrier" although they show the printer to have been shipped on the 16th and gave a tracking number, so UPS shows it to be on the truck for delivery today. Don't know whether they have the computer, too, or not since they were two separate order numbers.
Bird
   / I Hate Computers #75
Scruffy
<font color=blue>I've found the AMD chips to be good cpu's, but they sure require more cooling</font color=blue>
That may have been true from time to time, but I've found that the "winner" in the heat contest switches back and forth from time to time, depending on who made the latest advances. When my wife's CPU was switched to an AMD a few years ago, I found that it ran cooler than the equivalent Intel. Likewise, the winner in the instruction department is debatable. They both support the MMX instruction set, and they have both diverted from that time. In either case, M$ seems to support both relatively well.
ALso, both Intel and AMD have both converted to a RISC "core", and the macro instructions are largely simulated on both. However, the AMD "core" is more of a pure RISC architecture.
SHF
See what I mean? Adding those alternate ports will get you every time. /w3tcompact/icons/wink.gif
Bird
You can always put your finger on one, and if it smokes, it's too hot! /w3tcompact/icons/shocked.gif /w3tcompact/icons/wink.gif
But seriously, there are little temperature monitors you can put in a system that will warn you when things get too "toasty". Alternatively, you could just put a thermometer in back of the exhaust fan.
The latest P4's run higher clock cycles, but the AMD gets more work done per clock cycle (not a 100% true, but close enough if you're just doing business apps).
The GlueGuy
   / I Hate Computers #76
<font color=blue>GlueGuy</font color=blue>,
Like I had said, I hadn't kept up with that since 4 or 5 years back. Last I had looked into it was the early Pentium series, such as the P-90's or the early 586's, since then, it has been a 'blank' in my life....no time to play with digging it out....no interest either. Oops, better make that 5 or 6 years back...time flys when you're having fun! /w3tcompact/icons/laugh.gif
<font color=blue>Bird</font color=blue>, I hope your new machine arrives today!
If you are interested in the standard version of Sandra (free), you can download it from http://download.cnet.com/downloads/0-10014-102-0-1.html?tag=dir It is in UTILITY/MOST POPULAR and scroll down to Number 13. The software has all the information plus link for upgrading to the PRO version which has all the modules activated.
<P ID="edit"><FONT SIZE=-1>Edited by scruffy on 08/21/01 00:42 AM (server time).</FONT></P>
   / I Hate Computers
Scruffy, all the components of the new computer system arrived, and I'm using it now./w3tcompact/icons/smile.gif Unfortunately, I've got a few minor problems, such as not being able to get communication between the computer and the printer yet./w3tcompact/icons/frown.gif Some things I like, and some I don't like about this thing, but I reckon I'll get it worked out eventually.
Bird
   / I Hate Computers #78
Bird, re: <font color=blue>not being able to get communication between the computer and the printer yet</font color=blue>
My nephew had that problem with a new Compaq I got him (and an old printer that he'd had before). We set the parallel port to "compatible mode", instead of the ECP mode and it worked fine.
The GlueGuy
   / I Hate Computers
Thanks, GlueGuy . . . I think./w3tcompact/icons/wink.gif I'd probably try that if I had any idea what you're talking about and how to do it./w3tcompact/icons/crazy.gif
This is, of course, a new Dell computer and a new Hewlett-Packard OfficeJet G55 printer. The printer came with a parallel cable, but recommends you buy a USB cable if your computer has such a port. I didn't want to go to town shopping for a cable right now, so tried the parallel cable; hasn't worked so far.
Bird
   / I Hate Computers
GlueGuy, I found that "ECP" whatever that means, and changed sumpin'; removed a check mark from one of the boxes, and got 'er printin'. Thanks again!/w3tcompact/icons/smile.gif
Bird
2017 Ford F-550 (A55973)
2017 Ford F-550...
2019 Ford F-450 Altec AT200A 30ft Bucket Truck (A56858)
2019 Ford F-450...
(1x) 82inch Bucket for CAT Wheel Loader (A59213)
(1x) 82inch Bucket...
2014 CATERPILLAR 966K WHEEL LOADER (A52709)
2014 CATERPILLAR...
2015 Isuzu NPR 16ft. Box Truck (A56858)
2015 Isuzu NPR...
2115 (A58376)
2115 (A58376)
