I had my first 'problem' with my TC33D today....
   / I had my first 'problem' with my TC33D today.... #1
KrisHansen
Vermont
New Holland TC33d
I had my first \'problem\' with my TC33D today....
Well, I went to go out and play, er, I mean work with the blower today, but the tractor would not start. When I turned the key, I could hear a relay(s) clicking, and I knew it had power.. I checked all of the levers etc... turns out it had blown the fuse for the safety switches..
Luckily an easy fix!!
   / I had my first 'problem' with my TC33D today.... #2
Re: I had my first \'problem\' with my TC33D today....
Hey Kris I'm glad it was nothing serious on your TC-33D. Do you have any guess as to why you lost that fuse? Probably nothing too much to be concerned over unless the same one blows again.
   / I had my first 'problem' with my TC33D today.... #3
Some of the Operator's Manuals say that the safety switch fuse (#5) should be a 7.5 amp fuse. The corrected manual says it should be a 10 amp fuse. You might check which one you've got if this problem comes up again. Many people including myself ran into that issue.
</font><font color="blue" class="small">( Hey Kris I'm glad it was nothing serious on your TC-33D. Do you have any guess as to why you lost that fuse? Probably nothing too much to be concerned over unless the same one blows again. )</font>
I really don't know, other than I had the lights on.. I wouldn't think that would draw extra current though the safety switch circut, but if these things are anything like Audis, the electrical system is fussy..
</font><font color="blue" class="small">( Some of the Operator's Manuals say that the safety switch fuse (#5) should be a 7.5 amp fuse. The corrected manual says it should be a 10 amp fuse. You might check which one you've got if this problem comes up again. Many people including myself ran into that issue. )</font>
Thanks! to be honest, I looked in the manual at the fuse designations, but didn't look at the ratings. I pulled out a 10 amp fuse, and I put back in a new 10 amp fuse.
I just got off it, I can't get enough of that little blue machine!!!
   / I had my first 'problem' with my TC33D today.... #6
Kris,
I have also had the fuse blow once when I left the lights on. Nothing has happened ever since I remember to shut the lights off.
Marty
   / I had my first 'problem' with my TC33D today.... #7
Kris, I replaced the standard fuse in that fuse location with a circuit breaker.
Mike, I was thinking about that too.. Thanks!!!
6ft Wolverine Sweeper (A57454)
6ft Wolverine...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
LOT: (1) Shelf of Takeuchi & Donaldson Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (1) Shelf of...
2001 POLARIS RANGER UTV (A58375)
2001 POLARIS...
Giyi Auger (A57149)
Giyi Auger (A57149)
