I guess its true, nothing runs like a Deere
   / I guess its true, nothing runs like a Deere #11
Incredible. That tractor was screaming! There is a guy that can think on his feet too; say what you will about the safety of it. I think I would have given it a try in the same situation if I thought of it in time. Does anyone know if he stopped the spread of the fire?
Nothing said about it anywhere that I saw, but looking at the tail-end of the video shows the fire stopped where he started the plowing. Watch it again and take notice at the top left of the video as it ends. I would say his efforts paid off.
   / I guess its true, nothing runs like a Deere #12
I did notice that the fire appeared to be deterred by the plowed section; just couldn't tell if it saved the day. It definitely looked like a promising result. Hope it all worked out for him.
   / I guess its true, nothing runs like a Deere #13
It looks to me that it is a harvested grain field with stubble burning. I think he was keeping the fire spread down to save people's property downwind.
   / I guess its true, nothing runs like a Deere #14
I would disagree with that. The stalks are too tall to be harvested already. Right at the end when he pulls out onto the tilled area, you can see it is tall enough to be well up into the rim. That means it has to be 2 feet high at least.
   / I guess its true, nothing runs like a Deere #15
I agree RaydaKub. Unless they use a lot different technique in Colorado than here in Ea WA that is an unharvested field of some brand of grain. However, did you see all the tire tracks thru the field? Somebody, other than this farmer, has made a lot of passes thru that burning field.
I wouldn't think they would get that close to the fire to save stalks would they? At the end of the video just before he pops out of the field it looks like his tires are spinning. He must've had that tractor pegged wide open non stop. I hope for their sake they were able to save some of their field.
   / I guess its true, nothing runs like a Deere #17
I thought that most farmers have crop insurance.
   / I guess its true, nothing runs like a Deere #18
I had to do that once to save a field of cut hay but only about 40 acres. Its not fun, plain scary.
To this day there are washboards in that field from me running that disk bouncing as fast as the tractor would pull it. 12+mph?
   / I guess its true, nothing runs like a Deere #19
Wow....just wow!
   / I guess its true, nothing runs like a Deere #20
I've read elsewhere that he did. The field was approx 80 acres and 20 to 30 acres burned.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
SKIL SAW MITER SAW (A58374)
SKIL SAW MITER SAW...
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
