Oil & Fuel I found the level indicator
   / I found the level indicator #1
B2930 By the Water
Montreal, Canada
kubota 2920
I am a new B2920 owner and just found the hydraulic dip stick but, I did add too much oil. Does anyone know how to remove the excess hydraulic fluid. Also where is the best place to buy a repair manual or shop manual.
Thanks for your help,
Al
   / I found the level indicator #2
If you are a little over, leave it.. if a lot over, you can drain from a drain plug, of if you have a hydraulic line, open it and actuate that control... as to manuals watch Ebay and search on google... KennyV
Thanks Kenny,
I will do it tomorrow and let you know.
It is really appreciated,
Al
   / I found the level indicator #4
If you have some *clean* suitable clear plastic tubing, you might try siphoning some from the fill hole back into the container. You would have better control over how much you remove without making a mess or wasting it. ($$)
I don't suggest this unless you know how to siphon because you don't want to swallow any of it. Ideally you would use one of those cheap siphon pumps like they have at Harbor Freight, but you might not have one lying around.
Regarding an OM or WSM, assuming you can't find a used one, why not order it from the dealer or online at Messicks. As far as *good* repair manuals go, the price is not unreasonable at all.
   / I found the level indicator #5
   / I found the level indicator #6
* Does anyone know how to remove the excess hydraulic fluid. Also where is the best place to buy a repair manual or shop manual.
Al
Remove the drain plug and drain out about 3 or 4 quarts.
Check dipstick.
Slowly re add fluid if needed till it
reaches the full mark
Checking dip stick often.
2016 Chevrolet Tahoe 4x4 SUV (A46684)
2016 Chevrolet...
Brillion Seeder (A49251)
Brillion Seeder...
JMR Stump Bucket (A49251)
JMR Stump Bucket...
Dingo Forks (A49251)
International 781 Silage Harvestor (A49251)
International 781...
John Deere 7320 MFWD Tractor (A49339)
John Deere 7320...
