I Found a Crack in My 3510 Fuel Tank Today
   / I Found a Crack in My 3510 Fuel Tank Today #1
Stimw
Elite Member
N. E. Florida
I drove my 3510 a mile up to buy fuel today. After filling it up (6 gal) I noticed fuel seeping from the seam on the left fuel tank behind the step!
I drove it back home and syphoned 5 gallons back out and the seeping stopped.
I drove the left rear tire up on a 6" X 6" to lean the tractor away from the crack.
I took Brake Clean and cleaned the area very well, then cleaned the area with Acetone, then sanded the plastic to rough it up.
I had a pack of 5 minute Epoxy. I mixed it up, coated the area and then covered the Epoxy with a piece of vinyl coated canvas (to give it some strength) and squeased out the air bubbles.
I had the tractor parked in the sun to help with the curing.
It seemed like it worked very well. I will wait a couple days to put the fuel back in.
I poked a hole in a gas tank on a Buick back in the mid 70's on a dirt road. The Buick had a trailer hitch welded to the frame so I couldn't remove the tank.
I basicly did the same thing, clean very well, Fill hole with Epoxy and that time I covered the hole with a thin piece of aluminum.(throw away pie pan)
It was still on the tank a few years later when I sold the Buick!
   / I Found a Crack in My 3510 Fuel Tank Today #2
hah way to go! I did the same on my primary of my Harley the rubber bumper fellow off where the kick stand rubs.
I epoxied a nickel over the hole as well.
You make consider epoxying some mesh over you patch as the tractors vibrates a bit. Let us know how it works out!
   / I Found a Crack in My 3510 Fuel Tank Today #3
It will be interesting to see if this holds up. I did not think epoxy would stick adequately to the tank. Some plastics are about impossible to glue, and I thought these tanks fell into that category. But you may just prove otherwise. Keep us posted.
   / I Found a Crack in My 3510 Fuel Tank Today #4
Hey all - many of the plastic tanks can be welded with a soldering iron. I've performed this on two tanks so far and there is plenty of DIY/How to's via the Internet on how to make this repair. The tanks I repaired were gasoline tanks; one with two stress cracks along the mounting flange/tangs, and the other was filling a number of holes that were made from a determined rodent with a bad habit. The one tank with the cracks was repaired a number of years ago and still not leaking and the other is not leaking, so long as that rodent doesn't come back again.
   / I Found a Crack in My 3510 Fuel Tank Today #5
Any updates?
   / I Found a Crack in My 3510 Fuel Tank Today #6
I fixed 4 cracks in my LS fuel tank using JBWeld about 3 years ago and it is still holding.
It's still holding!!
I spread 4 loads of dirt with the tractor for a friend of mine up the road today.
The trick with any repair like this is to clean VERY WELL and allow plenty of cure time.
2016 Kubota M5660SU (A50123)
2016 Kubota...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
200387 (A51247)
200387 (A51247)
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
