I don't like it but you better use Mahindra filters
   / I don't like it but you better use Mahindra filters #31
It certainy isn't Mahindras job to make sure all aftermarket filters are adequate, in fact that is unreasonable. And even if I could grant that it is reasonable, and I won't, you used a filter that even the aftermarket did not specify for a Mahindra. So to make this Mahindra's fault, they need to be responsible for you buying an aftermarket filter for which not even the aftermarket supplier suggested the application. You just can't get there from here.
That tractor is built in Japan by Mitsubishi and I can assure you the OEM filters are very good. And while expensive, so are most filters for tractors.
It is irriitating that tractor filters are so expensive, and so I can appreciate the concept of getting something else that is equivalent for less money. But the aftermarket isn't strong for tractor filters until there is adequate volume. Why would Wix or Napa or Baldwin do all the testing just to sell a relative handful of filters a year? Remember that for every 1 tractor sold in the USA, there are about 80 cars sold. So the best aftermarkect coverage for filters is going to be the most common models with the most common filters.
As to why the #3 cylinder is the first to go, it is because the intake air sweeps into that area first allowing most of the dirt to go into that cylinder, although the center cylinder will have damage also, and to a lesser extent the front cylinder.
I also search the internet for nuggets of wisdom, and can totally understand. What you did was reasonable, but you probably did not realize the high consequence of a fllter being wrong or failing. You saved a few bucks on a filter, but it sounds like it cost you an engine. But your post has a lot of value in warning others to make certain they get the proper filters.
I'm sorry for the problem and understand the frustration, but I think directing your frustration at Mahindra doesn't make much sense.
   / I don't like it but you better use Mahindra filters #32
So I checked these forums to try and find replacement filters for my 2615 because Mahindra prices are freakin ridiculous. I mean $68 for an air filter...that's getting bent over when the napa equivalent is a 1/3 the cost. Well I went the cheaper route and am now paying over $1000 to get my engine repaired. The Napa filter didn't look exactly the same but folks on this forums said it'd work...WRONG. There is a dust trail down my intake to my rear cylinder which is now fried...new piston/rings, hone the cylinder, etc. All because Mahindra specifically makes filters so only theirs works with the tractor and then bends you over the table when you go to buy one. Thanks Mahindra...I guess the chinese manufacturing method has caught on in India. Sell it cheap and then screw people on the parts to fix it when it breaks. Besides this BS, I really like the 2615.
Give Newenglandtractor.com a call. They have been very good to Me. 1-866-393-0642.
   / I don't like it but you better use Mahindra filters #33
For the new 5530 owners be sure you get the correct filter if you have a Turbo. Had a filter delivered from my dealer, but it didn't match what was on my 5530 turbo. Called him and come to find out that the filter was for the non turbo engine. Brought back the wrong one and bought 2 correct filters.
idaho2
   / I don't like it but you better use Mahindra filters #34
SPYDERLK said:
Not sure why you would need to change an air filter much. I knock the dust out of mine every 100hrs or so. 1050 hrs and still in fine shape.
larry
I wonder about manufacturer's air filter maintenance recommendations too. My DK35 calls for cleaning the filter every 100 hrs. That makes sense but is even over-kill for my situation with very little dust.
But more puzzling is calling for it to be changed EVERY YEAR. What if someone puts on only 30 hours per year? I got a new filter for my 250 hr service which occured around 10 months. It was obvious there was no need to change it so it is still in the box with the machine at 329 hrs.
Why would there be a 1year limit on an air filter? Surely there is room for common sense.
   / I don't like it but you better use Mahindra filters #35
My manual states something along the lines of change the air filter when a lack of power is noticed.
   / I don't like it but you better use Mahindra filters #36
Im confused.. Why/how could the dealership/mfg deny the warranty when the 'correct' filter was used? Even if the MFG said no warranty, could WIX (since it was their filter) be held responsible?
Lets assume the dealership sold the Wix filter to the OP and this happened - could/should the dealership pay for repairs?
Brian
   / I don't like it but you better use Mahindra filters #37
I agree, think the dealer that sold him the wix filter should foot the bill, especially if te OEM filters are not made by wix.
Brian
   / I don't like it but you better use Mahindra filters #38
Conditions vary so much. If you were working the soil in dry dusty conditions you would be cleaning your filter daily. Or maybe twice daily. In areas with year round rain, you have about zero dust. We envy you! I'll agree common sense is needed.
   / I don't like it but you better use Mahindra filters #39
This are several scenarios that we could envision. If the tractor owner went to his Mahindra dealer and the dealer sold him an aftermarket filter that was wrong then the dealer needs to consider if his error caused the damage. But that would not be a Mahindra warranty issue. And that is partly why we do not offer aftermarket filters. We might save a customer $10 and then we can be the bad guy quickly.
If the customer went to an auto parts store and bought a Wix because he thought, from this forum, he could save a buck and the filter was wrong for the application, there is no help unless y'all want to chip in. If Wix actually specifies the filter for the application and it was a faulty filter, he can turn to Wix. One thing for sure is that the engine failed due to dust and using an aftermarket filter very much complicates things.
Excuse typos please, doing this from my phone.
   / I don't like it but you better use Mahindra filters #40
TRY E-BAY RUBICON TRACTORS FROM TEXAS.. THEY ARE WHERE THEY DELIVER THE MANINDRA TRACTORS INTO THE U.S. I BOUGHT THE 6 FILTERS FOR $89 AND SHIPPING.. ALL CAME IN SEALED MAHINDRA BOXES..
LOOK TO BE FACTORY SAME AS I REMOVED ...
BO..
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
bad boy zero turn 72 (A56859)
bad boy zero turn...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
