I did it
/ I did it #1
415
CT
CK20hst
Well I just sold my skid steer and finally ordered my CK 20hst with the sims cab with heat,work lights,kioti 54inch loader bucket,woods tooth bar,hooks welded on the bucket,woods 70X backhoe with the factory thumb.Rick W.[very nice people to work with] said about 2 or 3 weeks it should be ready for pickup.Did I forget anything?I will post some pics as soon as I get it home.
/ I did it #2
Maybe get your wife something...I always know a great wife, she lets her man get a Kioti!! lol /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ I did it #3
Congratulations! I look forward to hearing all about how much fun... uh, work you're getting done. You'll be very happy with your new helper.
John
/ I did it #4
Great set up. Just about what I have (minus cab) and I am very happy. /forums/images/graemlins/grin.gif
Why did you choose the Woods BH instead of the KB2365?
I also noted you got the 54" bucket. Somewhere I read that the 2006 versions all come with a 50" bucket. Is yours a leftover 2005. The one real advantage of the 2006 (and maybe later 2005 versions) is the suspension seat with real retracting seat belt holders. I would love to have that on mine but the retrofit costs almost $600 /forums/images/graemlins/frown.gif.
/ I did it
Well I went with the woods because of the curved boom,factory thumb,more reach and more digging strength.The machine will be used in my landscaping business as far as the 54 inch bucket Rick said it was a option but I will find out if it is a leftover or not.
Thanks Guys
/ I did it #7
Congratulations and welcome to the "Dark Side" /forums/images/graemlins/cool.gif
We're supposed to get a "sizable" snow this weekend, so I may wish I had that cab w/heater /forums/images/graemlins/smile.gif
Tom
/ I did it #8
That setup sounds familiar...
Sounds like you got my setup with a different BH and minus a snowblower. I look forward to getting a toothbar this spring to start some ground breaking on a garage.
Congrats on the purchase.
/ I did it
I LEARNED FROM YOU!!!!!!LOL /forums/images/graemlins/grin.gif
/ I did it #10
</font><font color="blue" class="small">( I LEARNED FROM YOU!!!!!!LOL /forums/images/graemlins/grin.gif )</font>
/forums/images/graemlins/wink.gif
/ I did it #11
Maybe just a back or box blade. I'm sure Rick can set you up.
Enjoy the tractor. They sure make work a lot easier but I don't tell my wife that. /forums/images/graemlins/grin.gif
/ I did it #12
Congratulations fellow Nutmeger! Welcome to the club! /forums/images/graemlins/grin.gif
/ I did it
Thanks guys.Rick called me yesterday[I was happy to answer the phone for a quick break my trucks were out cleaning up 24inches of fresh snow]He said they just unwrapping my new CK20 and it has a 3rd generation high back susp. seat on it,and I got one of the last 54 inch buckets Kioti had avalible.
/ I did it #14
Perfect. The 54" bucket is well matched to the KL120 loader. I still don't know why Kioti decided to drop down to the 50". Obviously some marketing decision because the 54 is a better match for the tractor.
I'd love to have the new seat to but cannot justify $ix bill$. I just ordered some $9.95 seat belt retractors and I'll give them a try this summer.
Congratulations.
/ I did it #15
</font><font color="blue" class="small">( Perfect. The 54" bucket is well matched to the KL120 loader. I still don't know why Kioti decided to drop down to the 50". Obviously some marketing decision because the 54 is a better match for the tractor. )</font>
I was told by one of the engineers at Kioti that the 54" was considered a little too big by the R&D department. I disagree as mine has performed quite well with no problems for nearly 400 hours. I guess they just wanted to make sure there was no overload, but I doubt it was ever a problem.
John
/ I did it #16
John, it still seems odd to me that they would cut the bucket size. Not sure exactly the cubic foot capacity of the 54" but assuming it is 8 cubic feet or less, even a full bucket of wet sand or gravel does not exceed the lift capacity to full height. (Note: this assumes 120lbs/ft3 material weight and admittedly uses the pivot point capacity but on the other hand I think 8ft3 is probably more than the 54" bucket holds). If you were going to exceed the lift capacity it would be trying to lift something that doesn't want to go such as a tree /forums/images/graemlins/shocked.gif and you could make that mistake with a smaller bucket just as easily. Besides, isn't that why hyraulic systems have bypass valves (is that the correct term)?
/ I did it #17
Congrats on your purchase. I have a LK3054 with a Koyker 155 loader and KB75 backhoe that I use for my landscape business and love it. I work it hard and have no complaints it's the best employee i've ever had /forums/images/graemlins/smile.gif. Its never late for work and almost always does what ever I ask it to. I think you will be very happy with your new CK.
Dave
/ I did it #18
Just a passing thought, could it have something to do with the center of gravity and stability? Narrower would be more stable I would think. My 2 cents worth! /forums/images/graemlins/wink.gif
/ I did it #19
That is a good point but Kioti already recommends adding 600lbs weight to the 3pt when using the FEL. Loading the rear tires is an option of course and that will add almost 500lbs I believe. I imagine even with the 50" bucket they would still require ballast on the 3pt so that seems an unlikely reason for eliminating the 54" bucket.
/ I did it #20
</font><font color="blue" class="small">( That is a good point but Kioti already recommends adding 600lbs weight to the 3pt when using the FEL. Loading the rear tires is an option of course and that will add almost 500lbs I believe. I imagine even with the 50" bucket they would still require ballast on the 3pt so that seems an unlikely reason for eliminating the 54" bucket. )</font>
I think it had more to do with lateral forces with the extra width of the bucket, not front to back. I suspect their thinking was that an uneven load could cause twisting damages more with the extra 2" on each side. Who knows?
John
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
JOHN DEERE 4440 TRACTOR (A62130)
JOHN DEERE 4440...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
