Rotary Cutter I D this Rotary Cutter?
   / I D this Rotary Cutter? #11
I can't find any identification on the gear box, and no shops around here seem to be able to match the input housing gaskets.
Anyone know where I can purchase a shim/gasket set for the input shaft housing to gear box? I replaced the seal, but the real leak was from the gaskets. The two gaskets were old and brittle, about 6" diameter, with 6-3/8" bolt holes, and .040" total thickness.
Patrick
I would get some gasket material from an auto parts store with the appropriate thickness and make the gaskets. Should be fairly simple and low cost.
I tried that. The distance between the inner radius and the bolt holes is very thin, and by the time I got it to fit over the housing, the gasket tore. I might as well just slop a bunch of sealant on the old gaskets and cross my fingers.
I can't believe these are so hard to locate. Most every gear box I see has what appears to be the same gasket or shim, and on line stores don't give dimensions.
Thanks again for your suggestions.
Patrick
2003 FORD F150 HARLEY DAVIDSON TRUCK (A58018)
2003 FORD F150...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
2011 UTILITY 53FT REEFER TRAILER (A58017)
2011 UTILITY 53FT...
NEW Fork Extensions (A59000)
NEW Fork...
LIGHT TOWER (A56857)
Great Dane Van Trailer 1989 (A56435)
Great Dane Van...
