I.D. this antique
/ I.D. this antique #1
ronaldbeal
Columbia
New Holland Boomer 37
Need help with I.D.
My dad called it a corn cutter... does not look like any I can find. Just curious what it is. No markings of any kind.
/ I.D. this antique #2
I'ld call it a "Spring tine tiller".
Different from some, but would serve the same purpose of breaking up the soil after mould board plowing.
/ I.D. this antique
What would the wheel thing in the middle do?
/ I.D. this antique #5
A picture from the other side would probably help. From this angle it looks like something pretty light duty that would hang from the four points and cover a pretty good area. My first thought is I could see that thing hanging from the belly of an old tractor raking something sandy like a beach or an arena. Is there a drawbar or some other attachment point on the other side?
/ I.D. this antique #10
Where? I just don't see them attached to each other. If that wheeled thing below rotated, it would catch the spring tines.
I think bcp has the right idea in post 6.
I'd try lifting the spring tine frame up with something and see if the wheeled thing stays on the ground.
/ I.D. this antique #12
Those two items don't go together. Doubt that's an antique either.
/ I.D. this antique #13
It’s definitely antique. The square bolt heads and nuts are a tell-tale for age. It does look like the cultivator part could be lifted off the cutter underneath. Have you tried rigging to the four lift points and seeing if it will lift off? Some gentle persuasion might help clear up whether it is actually attached or just hanging on because it’s tangled up.
/ I.D. this antique #14
they are definitely two item you see the twine going right in the middle of the wheel of the chopper and as far as antique what define antique ? 100 year old ? its old for sure, not sure what kind of attachment it is is, horse driven ? definitely not 3 point attach...
/ I.D. this antique #15
What defines antique in farm equipment I guess is what I'm not certain of. That thing was probably manufactured in my lifetime and I'm not quite ready to call that antique at this point.
/ I.D. this antique #18
Update... After feedback from you all, I went out and moved things around. Yes, it is two separate things.
Makes the explanationsView attachment 803251 make more sense.
Updated pic attached
Two separate implements, but maybe they were used together. A stalk rake and a stalk chopper. Maybe used in tandem. One under the belly of the tractor and one towed. Our old JD 530 has a hydraulic lift for a belly cultivator and also a three point. It used to be common to run two implements at the same time. And we got the JD from a small 40 acre corn farmer originally.
rScotty
/ I.D. this antique #19
Hopefully they are worth a lot of money.
My father had the implement on top, and I've thought about bringing it hope to use for a rock rake. The problem is that, like the two spring tooth harrows on the property and the old Oliver plow, everything is severely rusted from setting outside for 70 years.
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
White Metal Roof Vents (A64194)
White Metal Roof...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
New - Front mount rototiller
New - Front mount...
