I can't get no satisfaction!
   / I can't get no satisfaction! #1
Steverino
Central Connecticut
Kioti CK30HST FEL & BH
Cause I try and I try and I try and I try! -
Try to get grease into the blasted fittings on the front axel bracket group. There are two fittings labeled 4 & 15 in the accompanying illustration that need to be greased. When I attempt to do so neither will accept any. When I unscrew the fittings there is grease present in the joint and I can easily push grease through the fittings while they are out. When reinstalled though nothing move in and the grease will eventually push out from the grease gun / fitting connection. I do not see any grease emanating from any of the machined surface that makes up the assembly. Any insight as to how to get this connection greased and where the overflow grease should be seen would be appreciated.
   / I can't get no satisfaction! #2
They are a pain in the butt...
Try putting the loader on the ground and push the front wheels off the ground and pump grease into the grease fittings as you pivot the axel.
   / I can't get no satisfaction! #3
Just as Wallace suggested. I had the same problem you are having and lifting the wheels off the ground solved the problem.
   / I can't get no satisfaction! #4
Plus 3 to the others. I have the same issue. Apparently there is some positive pressure in these assemblies and that takes them of. Im guessing that this is air/water tight and when you lifit it up it changes that. Dunno but it works
   / I can't get no satisfaction! #5
Good to know! Thanks Rick!
I had not forced the issue, I had just thought they were full and didn't want to ruin any seals, will get to this asap!
Mike
   / I can't get no satisfaction! #6
Thanks for that post, I am having the same problem, will try with wheels off ground.
Thanks to all that replied, I tried the suggestion but still no success. :mad: The front end is very tight and does not rock back and forth very easily. Since there is presently grease in the joints and it does not appear to be exiting anyplace I can detect, I am going to just ignore this until the next time I do a lubrication. Hopefully as it wears in (200hrs now) this will improve. I may try on the next lubrication to see if I remove one grease fitting and lubricate the other if the grease will work its way completely through the joint, although it wouldn稚 seem that they would put one on each end if it was open completely through.
   / I can't get no satisfaction! #8
Same problem here w/ that same zerk -- a real pain to get grease in that and ripped my hand to pieces pulling the tip off the zerk...
But, worse for me is my grease gun tip on the Kioti zerks (especially loader zerks recessed in the pivot pins and such) when I push the gun tip onto the zerk and hold it on tight so grease goes into the zerk, all is well.
I need to attach the hose to another tractor and pull it w/ the other tractor to get the gun tip to remove (or it seems that way).
In reality I have to pull with two hands, and skin my hands or knuckles on some metal part of the tractor trying to pull the tip off. I'm afraid I'll break some zerks and have been gun-shy on using the grease gun because of this.
Anyone have a link or part number to a "sure to work" quality grease gun tip that I can use w/ stock kioti zerks that will make like easier?
I have two grease guns -- one my brother gave me I don't know who makes it with rubber hose making it tough to hold the hose and pump grease. If I put it on the zerk and done put positive pressure on the hose and hold it perfectly straight on the zerk, grease wants to go everywhere but into the zerk.
My other gun I bought new from northern tool and equipment... it's blue and has a hose and solid metal tube and tip that might be easier. It's pistol grip figuring it'd be easier than hose to hold and pump grease. Terrible to try and remove tip from Kioti zerks.
All tips and suggestions of a good grease gun and tip to use would be greatly appreciated.
   / I can't get no satisfaction! #9
I grease when the grandsons come to visit. I hold the tip on the zerk and they pump the gun.
malk315, I have an air operated gun that I purchased from tractor supply co. for around $30.00. It works real well on most of the fittings, except those mentioned before. The key for me is to clean out all the gunk around the fittings and then hold the grease gun tip straight in the fitting while squeezing the trigger. As I stated it works real well on most of the fittings, a couple are real finicky but doable without any bloodshed. IMHO air power is the way to go.
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2011 International DuraStar S/A Refer Truck (A47384)
2011 International...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
