Backhoe I can't figure this one out...
   / I can't figure this one out... #1
kooljets
New Richmond, OH
B3300SUhsd
Last year I bought a b3300su with a bh 76 backhoe and a 3 pt hitch. Yesterday took the backhoe off and was going to put on the 3 pt hitch BUT the frame that the backhoe connects to is blocking me from attaching the bracket of the check chain to the pin (lower link). Maybe I am missing something but I can't figure a way to get the rod (pin - lower link) to slide over far enough to allow the bracket for the check chain to slide onto the pin (because the frame is blocking it from sliding over far enough).
Now, if the frame for the backhoe wasn't there, there would be no problem sliding the pin over as it would slide into the cavity of the rear wheel.
Am I missing something or is this one of those secrets that everyone knows (except me)?
Right now, I see the only solution is to unbolt the frame from one side (looks like a major task) and slide the pin over, hook everything up and put the bracket back on. Not very handy if that is the case. Of course if this is the solution, I would just get a 1.25 hole drilled in the frame so that I could slide the pin through it.
I'd appreciate any help on this matter.
   / I can't figure this one out... #2
Does the hoe frame and hoe remove as a unit? Have any pics of the problem area?
No Coyote. The backhoe mounting frame is VERY securely mounted to the tractor. It would be a several hour job to remove and replace it each time.
I will see about getting some photos to show the problem more clearly.
KEWANCE 200 9' GRADER BLADE (A57192)
KEWANCE 200 9'...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2024 Hydraulic Trencher Skid Steer Attachment (A55851)
2024 Hydraulic...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
HEAVY DUTY 7' X 13' X 3.5' WAREHOUSE STORAGE SHELF (A54757)
HEAVY DUTY 7' X...
