I cant decide if I should keep fixing this thing...
   / I cant decide if I should keep fixing this thing...
Its Alive!
Once I got everything cleaned up it only took 2 hours to get everything back together. Total cost ended up only being $440.
The gear box went back together pretty well. The new seals that came for it are much better than the old one. They have the spring coiled on it to keep a tight fit.
The steering shaft & gear only took about 30 minutes since I had done it before. They improved this too apparently. They changed the bottom of the shaft to a sealed bearing. The old one used a bushing that would wear out and cause the gears to fail.
   / I cant decide if I should keep fixing this thing... #22
BMXER10 said:
Its Alive!
Very glad this turned out for you and that you are happy. You have a nice machine.
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
