i bought my first tractor... 2013 kubota mx5100 hst
   / i bought my first tractor... 2013 kubota mx5100 hst #1
ster009
canada
2013 Kubota MX5100
well folks, i bought my first tractor ever. its a mx5100 hst with grill guard, calcium loaded r4s,
LA884 fel and one set of remotes.i bought a landpride 2760 rotary cutter with chains. i hopefully
will have it delivered by the end of next week... cant wait... its worse than christmas. I'll post some pics
when shes in the dooryard!!
   / i bought my first tractor... 2013 kubota mx5100 hst #2
Congratulations!
   / i bought my first tractor... 2013 kubota mx5100 hst #3
Nice setup!! Hurry with those pictures when you take delivery.
   / i bought my first tractor... 2013 kubota mx5100 hst #4
Congrats! In my opinion the MX5100 is Kubotas "sweet spot" In their tractor lineup.
Think about having the rears filled with liquid ballast as well if you'll be doing any amount of heavy front end loader work.
Do you mind me asking why you went with the 2760 rotary cutter over the 2772?
By the way, that series of rotary cutters is an excellent quality cutter, you got yourself quite a nice package there!
   / i bought my first tractor... 2013 kubota mx5100 hst #5
His R4s are calcium loaded, so he is set there. I agree a 72" rotary would work well on that size tractor.
   / i bought my first tractor... 2013 kubota mx5100 hst #6
Agrred on the rotary cutter. I've tried 60" and 72" rotary cutters on my similarly sized tractors, and I just sold the 60". I'm looking at adding an 84" because the 72" doesn't come close to taxing them (39 and 45 PTO HP).
If you're going to lift anything 1k+ with the FEL, you'll want 1k or more on he 3pt to take load off the front axles (check your manuals for more accurate numbers). Loading the tires helps keep them on the ground, but doesn't help the font axle loading (and doesn't keep the rears planted as well as 3pt weight).
Pictures once it's dirty!
   / i bought my first tractor... 2013 kubota mx5100 hst #7
Congratulations, I agree the MX5100 is one of my favorite models and a real value with lots of features. As mentioned by others, I went with a 72" cutter, a LP RCR2672 for my similarly sized L5030 and it worked very well, it is now on my L5740.
Did you get bucket hooks?
We will be looking forward to your pictures.
   / i bought my first tractor... 2013 kubota mx5100 hst #8
Be careful. Go slow. MX5100 is a large FIRST tractor.
Check out the Safety Forum.
Thanks Piston. The tires are loaded with calcium. I thought hard about 60" or 72" and went with the 60" because I wanted something I could wiggle thru the woods with a little easier.
I've been all over the internet and TBN the last 4-5 months, talked to some other tractor owner friends and tried to build a package that will last for years to come... time will tell I guess.
no bucket hooks... I'll prolly add them myself
BUSH HOG BH114 4' ROTARY MOWER (A51243)
BUSH HOG BH114 4'...
Toro Z Master Mower (A50324)
Toro Z Master...
2014 JOHN DEERE 35G EXCAVATOR (A51242)
2014 JOHN DEERE...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
