I am surprised on Kubota Quality.
   / I am surprised on Kubota Quality. #1
Speedybon2543
Kubota b-7800
Having to repair a neutral roller bearing,which you're supposed split the tractor into which would be thousand + to repair. I flat rate repair so it was not so bad. (Thanks to this forum) My question did they improve this design. I do have over 2000 hours on it and I baby it. I think the B-7800 & B 2910 one of the best small Kubotas. Just this one fault. I was just wondering what it would cost to have the Kubota dealer would charge?
   / I am surprised on Kubota Quality. #2
How old is your tractor? Did you buy it new?
2000 hrs and finally needing repair work doesn't seem to bad to me but I don't put that many hours on a tractor.
Call your nearest Kubota dealer and ask for a estimate to do the work.
   / I am surprised on Kubota Quality. #3
agree w/above poster. are you original owner w/ maintenance log? 2k on a sub compact is a lot, similar to replacing clutch on an older gen machine. keep in mind your tractor is slightly larger than a lawn tractor. 2k hrs is a lot
   / I am surprised on Kubota Quality. #4
I don't agree that you should be having to do that repair at 2k hours and don't believe that is a lot of hours for a well maintained Kubota. I've owned a B7800, not very long, but agree it is one of Kubota's better tractors.
No idea what a dealer would charge though.
   / I am surprised on Kubota Quality. #5
actually agree with you, really depends on the maintenance thus far. on a smaller sump capacity, change intervals should be frequent & routine. utility tractor models w/ larger gearbox capacities & hd construction, maybe not as frequently
hope repair is tolerable for OP, much better than new purchase, regards
I miss quoted I only have 1250 hours. How I baby it always goes into my shop and never sits out at night. I keep it waxed and when I am done with it I blow it off. Repairs are always a priority. I change the Oil every fifty hours. And when it is out, I cover it with a blanket, to preserve the dash and seat. It’s just such a valuable tool I want to know that it’s ready anytime.
   / I am surprised on Kubota Quality. #8
I bought 2 new Kubota ZD-1211-72’s.
One is fine, the other has peeling “Kubota” decals with less than 20 hours on it.
HYD AUGER W/ 16" BIT (A52708)
HYD AUGER W/ 16"...
EDGER & FRONT TINE TILLER (A58374)
EDGER & FRONT TINE...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
TANK SEEDER (A58214)
40' High Cube Multi-Door Container (A53314)
40' High Cube...
